Plates already owning me :(
#41
Originally Posted by BLKWS.6
I think it may be my TPS. It just decided to kill me tonight, lol. Ideas? It is a $36 part.
#42
I had plenty of fuel (5/6tank by the guage and the miles on that tank).
It could be MAF, but I doubt it.
I think its TPS because of the fact that every now and then on a particularly humid day/week the rpms still like to slowly rise up to 2500ish or so, also, if the TPS were to be cutting out, that would explain why no backfires or other drama, its simply getting NO(or little) fuel/spark.
It feels EXACTLY like I just side-stepped the gas pedal and then got back on it. In NO WAY does it differ from what doing this would produce.
I will probably buy a new one tonight, do you think its an "in stock" part?
#44
Ussually missing or hesitation in a pull like up a hill means ignition trouble. How old are your plugs? Seems to me like the computer couldnt really tell if the plug actually lit off the fuel mixture.
#46
#47
That sounds more like how it is when fuel is cut off. A quick romp to the rev limiter should yield a similar experience albeit more dramatic since you are accelerating then all of a sudden it's not accelerating.
I would diagnose all avenues regarding the fuel system. filter is easy, then check relays, fuses and finally "listen" for the the sound of the fuel pump. When you prime the system, it takes around 30 sec before you can prime it a second time mind you.
#48
The fuel filter only has 5-6K miles on it. Car pulls HARD! up to 6K, tried it today, so I doubt anything is "stopped up". It just DIES intermittantly, and yes, I am pretty sure it is fuel related.
#50
Fuel pump relay is in the fuse block under the hood on the driver's side. I've heard of them going bad before, but usually that creates a hard starting issue rather than cutting out under load.
But the relay isn't too costly, and it's a super easy job to replace (takes more time to replace an air filter). Might want to swap it out.
#51
Originally Posted by Revelation Z28
you had GM put the TPS in?!?!
LMAO, the other day the receptionist joked about building me a cubicle so I could just stay there. All the people know me/my car by site, its great. I will say one thing about GM, or at least THIS DEALERSHIP. They are a pleasure to deal with and are damn polite/helpful!
#52
#53
Oh the bitch was hard to start too! (on the last occasion that it died) But it NORMALLY isnt...wierd. I will check it out! Is it dealer-only or will autozone stock?
#54
I've never personally bought one before, so I'm really not sure if autozone has 'em or not. But I remember seeing the receipt for one from GM and it wasn't very much. I takes about 5 seconds to swap it out. Popping the hood should be the longest part of the job.
#55
Meh, this just is teh suck If it is a plug-wire I should get a misfire code. I dunno what to think. I cant see 1 plug wire killing the motor. or destroying power TOTALLY intermittantly (I.e. not even enough power left to cruise in 6th at 65).
#56
Originally Posted by blue02formula
No code for me, but mine just had a stutter at about 1600 rpm. It sounds like it is getting worse in your case, and having starting issues, you may want to check your fuel presure to see if your fuel pump is going.
#57
The first time it pulled this crap they checked it. 58psi idle, 54psi WOT. There is no stutter, just on and off. Dead or alive, I or 0.
#59
I will only do a fuel pump swap after the pistol is to my head.
PS. the 58/54 PSI was STEADY, no fluctuation, they left it hooked up for a while and when it got hot it did not waver.
#60
Its not bad if you make a access panel, I just did mine it seems to run at 62psi. When it died on me at 73 mph on the highway it went down to 20psi. If it was a TPS I would think it would throw a code. I don't know, you got me puzzled. Good luck.
