Faster tach
Originally Posted by SSmokin 01
I put a 3 3/4" tach on the column. Have a shift light as well.
I don't care much for the 5" monster sitting on the dash either. Not to mention it calls out to the scum, "break my window and steal me".
![](http://i3.tinypic.com/wvo9rl.jpg)
![](http://i3.tinypic.com/wvo9x3.jpg)
Dan
Originally Posted by SLPSS99
I just got that same size in the Autometer Cobalt series, I was just wondering how you mounted that on your steering colum. I would like to do it the same way it looks great.
Dan
Dan
I put a piece of thin (1/16") cut to size rubber in between the base of the tach and the steering column to help give it some grip and also to keep it from scratching.
Then I just used a couple of large black zip ties. It's never moved and the ties don't stand out at all. Unless it's a show car that is.
I would have used a large worm clamp but the ignition switch is in the way. The ties will be one in the back and one in front of the switch.
The wiring just runs along the column down into the dash.
Just keep in mind that you won't be able to tilt your steering wheel all the way up with the tach there. I know some like to do that when getting in and out of the car.
It's not an issue for me and I'm 6'4" 260 lb.
i cant seem to find the post about the gauge cluster that puts in auto-meter gauges instead of factory ones. It looks pretty good and i think that would solve the problem. If anyone else knows what im talking about pm me i want that gauge cluster.
okay i found it alot quicker than I thought
https://ls1tech.com/forums/showthrea...+gauge+cluster
thats the thread that shows a nice custom cluster, and the lower link is one that shows what you need to wire them up
https://ls1tech.com/forums/wiring-stereo-electronics/445782-so-you-want-replace-your-cluster-aftermarket-gauges.html
this is another pic of one
https://ls1tech.com/forums/showthrea...=gauge+cluster
I think those top 2 links are the same bro.
A long time ago a guy was starting to make a custom cluster with part numbers to the gauges to use. It was pretty nice looking. Can't find anymore.
Here's some Info on after market gauges, wires, etc..
And I don't know what to tell you about speeding up the factory tach. :shrug:
![Thumb](https://ls1tech.com/forums/images/smilies2/thumb.gif)
but back on subject i think that is probably what the orig poster is looking for and a pretty killer set up... and i really like the look of the carbon fiber one in the third link that I put up there if you drop in some nice gauges it would look sick the autometer nexus are my fav heres a link
http://www.autometer.com/demos/nexus/
