Oil Question
Oil Question
I have seen lots and lots of threads on oil and what type to use. It seems like most guys are reccommending to use 0w40 rather than the 10w30 the factor reccommends. is that ok to use is texas with this f-ing heat??? i live in san antonio and use my car as a daily driver. My only upgrades are lt's, X=pipe, lid and k&n if that makes a diff. Thanx for any input
0w40 is thicker than any 10w30, so it should be even better in the summer heat. Don't let the 0w fool you, that just means it flows like a 0 weight oil in extremely cold winter temps (which is a good thing). In the summer, the 0w40 will still be thicker than 10w30.
Originally Posted by staringback05
^^^ hes right, but i personally didnt like the 0w40 compared to the 5w40...felt like the engine was running on sludge...same brand of oil to
I'm confused about what you mean by 'sludge'? Can you explain further?
Originally Posted by RPM WS6
I've thought about making that switch as well but the 5w40 is much harder to find around my area.
ok been searching my a** off for the 10w30 GC. I know What to look for as far as the serial numbers on the bottom and Made in Germany on the back, but i went to 6 different stores and all i found was the same old stuff made in NJ. Any tips where to find it?
Most Autozones recently quit carrying it. Can still get it from some online vendors like WS6 Store. http://theoildrop.server101.com/foru...e=0#Post836448
