Stock WS6 13's
Originally Posted by Omega Doom
I ran a 8.6@84 with a 2.06 60ft with 87 octane in 2245 Da andhigh 80 degree heat and thats a stock A4 WS6, I think thats close to a 13.4 1/4?
I went 13.6 at 106 when I was bone stock. My first run ever I spun to like 100+ft and missed third and still went 14.0 at 102. Something is definitely wrong. He is only trapping 74 in the 1/8.
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
Originally Posted by supernova1972
Why did you put 87 in an LS1? Thats really stupid.
From these comments I'm starting to think somthing is wrong w/ this car.
I ran a 8.80 @ 82 at the 1/8th mile (no 1/4's around here) which when comparing timeslips to those in the timeslip database came out to 13.58 @ 103.x With a BAD tranny mount (i pulled the mount out next week and it fell off in three pieces)
stock WS6's are easily capable of 13.2 - 13.4 times.
I ran 13.5's to 13.7's stock with the 345hp package. Thats with low 2.2 60's and 30psi in the factory tires. The second time I went the car was lowered an inch with LT's through a LM2 and was cuttin steady 13.4's with an almost 2.3 60'. That 60' is killin me. I def need DR's.
Get that car back to the track, shift at 6000 each shift, and get those 60's down
I went 13.54@101 in a bone stock 97 LT1 T/A!! Stock intake/exhaust etc...if that LT1 car could do it, a Ram Air LS1 can![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Driver mod is in order
#33
Originally Posted by tee-boy
I like your answer. These guys are relatively young (early 40's). One guy is an LT1 guru. He built a C10 pick up from ground up (he has pictures to prove) and put in a LT1 from a camaro. His truck hits 14.4.
Reason I ask is I took my WS6 to track for 1st time recently. Below is my time slip. I hooked up well on the below run w/ M6. Car has 65K miles and is near stock. Either I'm doing something wrong or my car sux.
60' 2.24
1/8 9.527 at 74 mph
1/4 14.693 at 96 mph
60' 2.24
1/8 9.527 at 74 mph
#34
i have a question for you are you a lt1 or ls1 theres is going to be a really big difference in times. i had a 96 ws6 ram air and the best i could get it to run was a 14.1 in the quarter now i drive a 02 ss camaro i have a lid and im runnig 13.3 at 106 with a 60' at 2.1 with street tires. i would like eveyone else start by runnig 93 octane lower tire pressure and go from there.
chris
chris
#35
chris
chris
#37
Is running 87 octane going to affect times that much? Because my parents are absolutely convinced that the $2 they save with 87 octane is worth it. I know the car needs 91 (no 93 around here), but could someone explain why exactly 87 is bad for it?
#39
#40
Originally Posted by Pewter02WS6
Are you kidding me? The computer in the car is programmed for the car to run on 93 or 91 at least. So when you put a lower octane fuel in the car the computer reads it to be inadequate for the motor so it retards timing and takes away power. And $2...really....come on. You can save your $2 in change you get back in about two days worth of spending cash. So tell your parents to save their change at the end of the day and use it for gas at the end of the week when they need to fill up lol. Basically the higher the octane the better the performance.
