General LSX Automobile Discussion Non-technical LSX related topics.
Stock WS6 13's
Old 06-23-2007, 09:14 PM
  #81
the_merv's Avatar
Originally Posted by WS6NIGHTMARE
Did you put your gears in? Or are you assuming it has them? A regular M6 TA and an M6 WS6 TA both have 3.42's in the back.
Earlier you were asked if you let off before the end, you said "anything is possible" Did you or didnt you?
^^Someone else sees it also..
Originally Posted by tee-boy
I cleaned the MAF w/ non chlorine brake clean as well as ran a can seafoam thru tank and half a can thru brake booster, and I picked up a tenth - 14.05. Car still is down on power. 2 other stock f bodies at track tonite and both were low 13's. Both were 02's so have the LS6 intake (I doubt if that can account for half a second or more). My 60's were at or better than theirs but I'm still only trapping 100mph and barely into 4th gear. My best run tonite was actually a 14.001.
Something is definately up..could be a Tune issue. Possibly could be getting a False Knock as it goes up in RPM's.
Old 07-07-2007, 12:16 PM
  #82
tee-boy's Avatar
Gears have been in. Don't need to assume, I have proven it by clocking my rpm in 4th at 80 mph and looking it up on one of those charts.
It would be nice to have some datalogging software to see if, where, and by how much this thing is knocking. Oh well, all I have is OBD1 tuning software.
Woke up this morning to do a compression check, and decided against it after I reached in there (with gloves) to take the no 1 plug off with engine hot. Decided I'd rather keep the hair on my arms and have someone else do it (this ain't no Gen 1 SBC). My padnuh buddy is going to charge me 200 to do compr check on Tuesday. Maybe that will tell me something (like a bent exhaust valve-car does backfire out exhaust from time to time) or bent push rod.
Old 07-07-2007, 12:26 PM
  #83
021less's Avatar
yes, low 13's is easy, my times are in my sig bone stock down to the paper filter and goodyear f1's. It is an ss but same damn thing!
Old 07-07-2007, 12:49 PM
  #84
DVS99TRANS's Avatar
What's the on milage on the car??? Valvetrain/clutch/or you need a tune(not a tune up) pretty damn bad. You should be close to see level, but should be running high 13's worst case scenario even if it's a million degrees outside. Does it already have a handheld tune in the PCM? That would explain alot.
Old 07-07-2007, 01:38 PM
  #85
greysteel_M6's Avatar
A bent push rod is easy to check for, pull the valve covers and tug on the rocker arms, any slight give or diviation is a dead giveaway. /\ A hypercrap tune would also explain it. Maybe take it in for a stock tune.
Old 07-07-2007, 01:57 PM
  #86
tee-boy's Avatar
Default thx
68K miles... I've been wanting to take it in to dealer to have it reflashed. Will wait to see after i get compression results. It could be anything. The thing idles smoothly but there is a random hesitation and vibration from time to time (I wonder if other LS1's idle any smoother). Could be detonation, but only reason I could think of this at idle would be a valvetrain issue.
Old 07-07-2007, 02:08 PM
  #87
SchultzLT1's Avatar
if its vibrating at idle thats could be your problem, since your 60' is normal-ish and you say your stayin on it hard, your problems may be up top.....
go to the Seafoam sticky in general maintenance and Seafoam that bitch.... maybe shes all gunked up? I haven't seen anybody else recommend this yet. Its cheap and doesn't take long and for some makes a HUGE difference depending on how the car was maintained.
My SS doesn't have a Lid and has the base SLP exhaust, 0 SLP options, just a short stick and it ran 13.5x @ 104.
have u ever considered letting someone else drive it and see if there is a difference?
Old 07-07-2007, 03:00 PM
  #88
tee-boy's Avatar
I've seafoamed three times (once thru tank and twice thru brake booster). I drive harder than the other amateurs at the track. In fact, I launch at 2300 when most of them are launching from a dead idle. Don't trust anyone else to drive my car. When I launch from an idle, I run a 14.3.
Old 07-07-2007, 03:11 PM
  #89
kyle91z28's Avatar
Originally Posted by BLK02TA
You may want to look into a serious tuneup or a compression test......or both!!!
Just to let you know, I ran better than that stock in my 91 camaro, with 100 less HP lol.
Old 07-07-2007, 03:36 PM
  #90
SchultzLT1's Avatar
try launching at like 3500 maybe?
when i just started out i launched at 3000
Old 07-07-2007, 08:11 PM
  #91
DVS99TRANS's Avatar
68k, not to shabby. Pretty low miles. Since it's had a gear change, does it still have the stock diff??? If it's aftermarket, could be the clutches. You're not throwing any codes, so I won't think it will be anything rotating under the hood unless maybe a bent pushrod, but you still wouldn't run that bad. I don't want to get down on ya, but on my first run ever with my TA I missed 3rd really bad and still ran a 14.1@99(was a little nervous). Your TA has more power than that. Something is definitely wrong
Old 07-08-2007, 12:06 AM
  #92
myk
myk's Avatar
I wouldn't go with a compression check, yet. This car is obviously making power, however it isn't living up to its potential. This really sounds like a tuning issue. If you're going to fork out hundreds, take it to a speed shop, hook it up to a dyno and see what they say. Damn it, now I'm curious to see what my bird can do...
Old 07-08-2007, 12:26 AM
  #93
phrozen755's Avatar
I like your answer. These guys are relatively young (early 40's). One guy is an LT1 guru. He built a C10 pick up from ground up (he has pictures to prove) and put in a LT1 from a camaro. His truck hits 14.4.
Reason I ask is I took my WS6 to track for 1st time recently. Below is my time slip. I hooked up well on the below run w/ M6. Car has 65K miles and is near stock. Either I'm doing something wrong or my car sux.
60' 2.24
1/8 9.527 at 74 mph
1/4 14.693 at 96 mph
Were you driving against F5 hurricane winds?
Old 07-08-2007, 10:30 AM
  #94
tee-boy's Avatar
Default reply
re-read the post. did a tune up and now running 14.00X at 101.
Old 07-08-2007, 01:17 PM
  #95
phrozen755's Avatar
congrats! Good to hear you got that cleared up
Old 07-08-2007, 01:33 PM
  #96
tee-boy's Avatar
Default dd
glad I could set you straight.
Old 07-08-2007, 01:35 PM
  #97
JD_AMG's Avatar
Nice, I think you should be able to trap atleast 104 though.
Old 07-08-2007, 02:34 PM
  #98
Thule's Avatar
i went to the track on my car with fried clutch.. and i mena fried i had to haul it from the track, because of the vlutch i couldn lunch it, i went 13.7@103 with over 2.7s 60f, and 14.03 with 3.2 60f,
then i borougth my friends catback only 2002 car, i went realy low 13's on that car, 13.008 and 13.3 with 2.2-2.3 60f, stock car, my friend wen 13.1 on his bone stock 98Z, all m6 cars,
and girl i know went 13,8 on a bone stock 95 lt1 A4
Old 07-08-2007, 07:11 PM
  #99
tee-boy's Avatar
Default Iceland
did you do all this in Iceland?
Old 07-12-2007, 11:39 PM
  #100
tee-boy's Avatar
Default comp check
Brought to mechanic for compression check. He tells me all cylinders are at 145 except no 3 which is at 150. I can't seem to find any compression no's for LS1. This seems low to me, but atleast they are all in line. Any thoughts?
