So I searched and only found the obvious...
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
My TA says that it has the WS9 option (firebird formula). However one can clearly see that it is a TA, not a firebird. It has the raised spoiler, front clip with larger foglights, leather int, t-tops, etc. The reason I know it has the WS9 option is because I requested the list from the joshp14 in the forums. However, when I search all the forums say there is no such thing as a Trans Am/formula. If there is then what exactly does the WS9 option entail that my TA doesn't already have (i.e. the drivetrain). Any help on this would be appreciated.
Here is the option list:
OPTION CODES
AAA - STANDARD EQUIPMENT PROCESSING OPTION AG1 - 6-WAY POWER DRIVER SEAT
AK5 - DUAL FRONTAL AIR BAGS
AQ9 - CUSTOM BUCKET SEATS W/ADJUSTABLE LUMBAR SUPPORTS
AU0 - REMOTE KEYLESS ENTRY
CC1 - LOCKING HATCH ROOF, REMOVABLE
C60 - AIR CONDITIONING, CUSTOM
DE4 - HATCH ROOF SUNSHADES, REMOVABLE
DG7 - DUAL POWER SPORT MIRRORS
DL5 - DECAL ROADSIDE SERVICE
FE2 - SUSPENSION SYSTEM, HANDLING
FE9 - 50-STATE LOW EMISSION VEHICLE
GU2 - AXLE RATIO 2.73
G80 - LIMITED SLIP TORSEN REAR DIFFERENTIAL
IL2 - TRIM INTERIOR DESIGN
J65 - BRAKES, PWR 4-WHL,DISC FRT & RR
K43 - 102 AMP GENERATOR
LS1 - 5.7 LITER SFI V8 ENGINE
MX0 - TRANSMISSION, 4-SPEED AUTOMATIC
M30 - AUTOMATIC TRANSMISSION
NF7 - FEDERAL LOW EMISSION
NP5 - STEERING WHEEL, LEATHER WRAPPED W/LEATHER WRAPPED SHIFT ****
PDC - SECURITY PACKAGE CONSISTS OF: THEFT DETERRENT SYSTEM REMOTE KEYLESS ENTRY PDN - POWER PACKAGE
P05 - WHEELS, 16" CHROMED ALUMINUM
QFZ - TIRES, P245/50ZR16, ALL WEATHER
SLM - SALES STOCK ORDERS
STE - ASM PLT ST. THERESE
T43 - SPOILER, REAR DECK LID
T78 - HEADLAMP CONTROL DELETE
UA6 - THEFT DETERRENT SYSTEM
UB3 - RALLY GAGES W/TACHOMETER
UK3 - LEATHER WRAPPED STEERING WHEEL W/RADIO CONTROLS
U75 - POWER ANTENNA
VM3 - BUMPER STD IMPACT 5 MPH FRT &RR
V12 - POWER STEERING COOLING SYSTEM
V73 - VEHICLE CERTIFICATION U.S.
WS9 - FORMULA OPTION
W55 - RADIO ETR AM/FM STEREO W/COMPACT DISC PLAYER AND GRAPHIC EQUALIZER, INCL. CLOCK, SEEK UP/DOWN, REMOTE CD PRE-WIRING, MONSOON 500 WATT PEAK POWER W/10 SPEAKER PREMIUM SOUND SYSTEM AND STEERING WHEEL, LEATHER WRAPPED, W/RADIO CONTROLS
Y82 - TRANS AM OPTION
1SA - OPTION GROUP - 1SA
10U - PAINT, ARCTIC WHITE
19I - INT TRIM, EBONY
192 - TRIM, EBONY
6BT - COMPONENT FRT LH COMPUT SEL SUS
7BT - COMPONENT FRT RH COMPUT SEL SUS
8TJ - COMPONENT RR LH COMPUT SEL SUSP
9TJ - COMPONENT RR RH COMPUT SEL SUSP
Thanks guys, I Also attached some pics.
OPTION CODES
U75 - POWER ANTENNA
192 - TRIM, EBONY
I also have a 98 ws6 and on my door I have the ws6 option it does NOT say ws9 so maybe they changed things later on in the years. I thought the ws9 was the formula ws6 like the ws6 hook and no rear spoiler? To confusing for me im tired
quadd
quadd
All basically start as a Firebird, WS9 should be on both Formula's and TA's - gives it the V8. It is on my door sticker and build sheet(it kinda became a Formula before becoming a TA), as should Y82 for a TA
I have the following codes and descriptions(found a list of the RPO's along with their descriptions on the web somewhere some time ago, try a google search)
WS6 - Appearance & Performance Package, Formula/TransAm
WS9 - Model Conversion, Formula
Y82 - Merchandised Package, Pontiac Firebird TransAm Base
Originally Posted by 1meantransam
im pretty sure WS9 is an aftermarker deal, not factory made... but i could be wrong stranger things have happend
ws9=v8
