Need to settle a Top Speed argument
#41
i had my vert t/a up to 145-150
my ss went to 155 a few times and was still pulling
this one i have had at 140 but i dont wanna make too many pulls on my stock motor that high with my p1sc
#44
My 95' Formula w/ Z rated hit 165, then I slowed to 145 and got passed by a New York State Police 98' camaro interceptor going at least 165. Nearly blew me off the road and I was 2 lanes over. Sometimes even cops can't resist the urge. One of the greatest and scariest moments of my life. I had a guy on my submarine that didn't believe me and after a brief run to 150 would never ride with me again. Trust me give them all a ride.
#45
I owned a 94 TA LT1 and it would not go past the speedo limit. I did not have the 150 mph speedo though. I can't remember if it was 110 or 115 but the car sounded like it was cutting out (it would slow down about 5mph then speed back up). I have never had this prob in my Ls1. Never hit 155 (have not tried) but 135mph racing a stang on the interstate ( did not need to go any faster proved my point ).
#47
Took mine up to 143 and backed off of it. At 128 I hit 4th gear (A4 automatic). When I hit 143, I still had the rest of the entire gear range. I don't think it would have taken very long to hit 200+ ... but once you get up over 150-160, the wind drag makes it take longer for the car to reach higher speeds. Of course, I have no speed limiting ... all that **** got tuned out the 1st month I got my car.
#49
Moderator
Originally Posted by CaseyEaterMach1
That is crap my Mach 1 is limited at 150 and it was built in Dearborn Michigan also check out this article comparing the 87 GT and IROC http://www.stangbangers.com/87_Musta...-Z_Article.htm and the top speed of both cars which are built in America is just under 150.
I had 3 IROC's and 8 Fox's.
#51
#53
I hate ignorant people. They used to talk crap about my '98 Cadillac Seville STS. Mine is governed at 130mph. It'll do that easy. Z rated cars will do 155mph. Yet, people still think because it's American and a "Cadillac" that it's slow and excessively restricted. Gets on my nerves.
#55
In the case of the LT1, the OP is correct that if the speedo is the 115 and it came with less than z-rated tires, there is a speed limiter. This was 108 on the 94-95 model years. Not sure on 96+. Also there was no speed limiter on the lt1 if z-rated tires came on the car (unlike the ls1's where the limiter is 163).
#57
It's correct that the non z-rated cars were speed limited somewhere around 115ish. The cars that came with z-rated tires had no speed limiter, at least until 96 when the obdII systems came onboard. I believe with OBDII the speed limiters came into effect somewhere in the high 150's, low 160's, it may be the same 162 as the ls1 cars.
#59
I had the '99 Grand Am GT I used to have to its limiter at 126. Hell the new Impala SS's are supposedly good for 154. However, I wouldn't feel comfortable doing that in the Imp.
#60
