first time at track
first time at track
went to the track for the first time did just 2 runs here r my numbers
1st race
rt .503
60' 2.346
330 6.339
1/8th 9.408
mph 81.05
2nd race
rt .468
60' 2.157
330 5.784
1/8th 8.721
mph 84.04
my mods r ls6 intake, slp flowpac, pacesetter longtube headers and ory y pipe, ported and polished tb, 3.42 gears, 2400 stall , street tune, tb bypass would that be about normal or do i need to practice my driving? thanks in advance
1st race
rt .503
60' 2.346
330 6.339
1/8th 9.408
mph 81.05
2nd race
rt .468
60' 2.157
330 5.784
1/8th 8.721
mph 84.04
Well i am assuming your having traction issues with those 60' times. Cut better 60's and you should be low 8's. I ran a 8.5 bone stock with a 1.9 60' so get to work on those 60's and you'll have some pretty respectible times
easy offffffff the gas bud
what kinda tires do you have? are you just flooring it off the line? can you tell when you have tire spin? with those mods you should be doing better times
Don't worry about it man.
I just went to the track yesterday for the first time and my best time was:
R/T- .929
60'- 2.198
1/8- 8.371 (88.68MPH)
1/4- 12.835 (109.63 MPH)
My car is cammed and it puts down 382whp and only managed that time. Practice, practice, practice..
Next time I run it, I'm gonna start off easy because all I do is spin at first...
Good luck.
R/T- .929
60'- 2.198
Good luck.
My last pass was:
2.184 60'
8.558 @ 86.96 1/8
13.087 @ 108.72 1/4
That was about 3/4 throttle off the light with a small amount of wheel hop and getting into it once I got moving. I wanted 12's so bad I mashed it the next pass and sat still spinning for a good 3 seconds, haha. I didn't even stop at the booth for my slip. Had to be 15-17 seconds.
I'm curious if street tires become more slick with each pass because the first two were wheel hop, the last was rear end going back and forth sitting still. Granted I put it to the floor right away. I couldn't hear the announcer in the tower, but a friend said he shouted 'WHOOOOAAAA!'. Blah.
2.184 60'
8.558 @ 86.96 1/8
13.087 @ 108.72 1/4
yah dude those numbers sound right as long as your spinning but with that 60' ft time u definately are. just get a pair of drag radials and ull be hitting under 2 secs with good driving and curious what temp was it outside when u ran
