need some help ls6 manifold
There should be a P/N cast into the passenger side of the intake, between the #4 and #6 injector bosses. The part number for the LS1 intake I have in storage is 12560688.
LS6 intakes also don't have the EGR hole (on top of neck right behind throttle body). Some places modify them to make them compatible with EGR-equipped vehicles, though. I'd go the P/N route myself.
Deranged Rat Fink
1 Post
Been covered a gazillion times here but what the hell? Look directly behind throttle body at intake. Is there a large blank recess at top of intake with nothing in it? LS6 . If there is a large solenoid with line coming out , EGR on LS1 intake.
AFAIK if the p/n is on the driver side it is a LS6. If the p/n is on the passenger side it is a LS1.
The only sure way to check with it on the car is to look at the p/n.
Originally Posted by night ghost
biggest thing to look for is to see if there is an egr delete if there is then u got a ls6 manifold
