How does the Oil Change indicator work?
What parameters make it come on? It can't be mileage or time because mine will come on then off then on and off (just started today and yes, it is due). Is there a sensor that samples oil purity? Optical sensor maybe to check clarity? Anyone?
You are living in a fantasy world! I believe it just works by tracking the number of miles since it was reset,as well as some driving habits and driving conditions that the computer senses. You can believe the one about an oil purity sensor if you want - that would be one hell of a sensor!
It's called the GM oil life system, several factors play into when it illuminates - mileage, temps, driving habits, etc. - explained in the owners manual - can come on anywhere from 3-10K. Once it comes on it will for every ignition cycle on start up for a few seconds until it's reset. Since you're due for a change just reset it when you get it changed. Personally I don't use it, change mine by mileage.
Originally Posted by ssfast99
easy way to get rid of it. put the key in the ignition and turn to the on position. push the gas pedal three times and then your good.
That method works the same as the one in the owners manual, and doesn't reset the trip odo too.
BTW if you need a manual http://shbox.com/pdf/manuals.html
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
