comaro ss 98 (stock) vs ws6 ram air 2000 (stock)
I raced my stock 98 trans am (base model w/ original motor and nothing but cut-out and lid) against a 02 trans am (also base model w/ cut-out and lid) he pulled me by a nose, drivers were basically the same, we switched cars and the result was the same the 02 would always pull by a nose...
Both cars will produce similar horse power numbers and torque ratings, so it really all depends on the driver, it is not a matter of which car is faster, it is a matter of who the better driver is.
The Camaro will be faster. Camaro's got 70hp boost over Trans Am's. Bigger cams, more valves and an extra cylinder.
Here is some more info:
https://ls1tech.com/forums/new-ls1-owners-newbie-tech/213148-jrp-s-faq-commonly-asked-questions.html
Cocamaro?! Geez NooB it's CAcamaro
And like the guys were saying, same freaking car different body panels. That's all there is to it. Nothing more. Same engine, trans, rearend, suspension. Same car.
98' bigger cam, smaller injectors, crappier heads.
99+ smaller cam, bigger injectors, better heads.
01-02 LS6 intake, better rod bolts, smaller cam, bigger injectors, ls6 heads, some ls6 blocks, !EGR, ls6 clutch, better flowing exhaust manifolds.
98-99 = bigger cam, same heads, same exhaust manifolds
00-02 = smaller cam
98, 01-02 = bigger injectors
01-02 = better exhuast manifolds, SOME LS6 blocks, all LS6 intakes, LS6 clutch + hydralics, !EGR
98 = shitty computer
This has been beat down many times, 98-99 are usually slowest stock, 00 is in the middle, and 01-02's are usually a lil quicker (by a nose like the other guy said)
#33
[QUOTE=djsanchez2;7887705]Cocamaro?! Geez NooB it's CAcamaro
01-02 LS6 intake, better rod bolts, smaller cam, bigger injectors, ls6 heads, some ls6 blocks, !EGR, ls6 clutch, better flowing exhaust manifolds. 01's n 02's with LS6 heads? You might as well call it a LS6, lol.
#35
Good catch. I've been looking for the Year change thread, but havent been able to find it.
**Edit here is the list**
https://ls1tech.com/forums/showthread.php?t=213148
Wow you guys are slow!! This ended a while ago. Also learn how to read the posts before opening your fat mouths. Did you not see that i corrected myself and posted the link to the ENTIRE list?!!?
**** you people kill me.
#36
WOW some of you guys kill me, the cam size and injectors isnt goin to make a difference on a stock car. The only thing that might yeild a few more is the exhaust manifolds but still your talkin 1-3 HP some of the LS1 engines varried more then that. What it comes down to is its the SAME CAR. Its like a eclipse and a talon SAME car different names. Just b/c a T/A costs more dont make it better.
