comaro ss 98 (stock) vs ws6 ram air 2000 (stock)
which car is the fastest?
the ws6 has a manual transmission so does the ss.
The WS6 is slightly torquier than the SS, and I believe is .2 seconds faster with automatics. It really depends on the better driver with manuals. I wouldn't be surprised if the driver's weight made a difference (considering there a 50lb difference or so)
How is a WS6 Torquier considering that they are the same car with diffrent bodies?
basically the same motor 98's heads were different then the 00's and didnt flow quite as well
same trans
same rear end gears
the T/A is slightly heavier
The T/A is also a lil more streamlined though
the T/A ram air works a lil better thewn the SS
but i like the SS better
the T/A's in my opinion have too fat off an ***
even tho i like their front ends better then the camaros
more things will decifer which is quicker then just the car i.e. like the driver mostly
and even both stock vehicals can make different hp n tq ratings even from the factory
same trans
same rear end gears
Cocamaro?! Geez NooB it's CAcamaro
And like the guys were saying, same freaking car different body panels. That's all there is to it. Nothing more. Same engine, trans, rearend, suspension. Same car.
98' bigger cam, smaller injectors, crappier heads.
99+ smaller cam, bigger injectors, better heads.
01-02 LS6 intake, better rod bolts, smaller cam, bigger injectors, ls6 heads, some ls6 blocks, !EGR, ls6 clutch, better flowing exhaust manifolds.
Negative, only 01-02 had the LS6 clutch, oh yeah ungraded hydralics for the clutch too. 98-00 had the regular LS1 clutch.
I might wrong about the LS6 heads. Didn't some come with 243 heads? Or were they all 241 heads?
Thanks that was a lil confusion on my part. I could have sworn i've heard of some 02's coming from the factory w/ 243's. There was a Z28 in the internal section that stated his came with them. But i know everything else i stated was right. Oh and one more addition to the above.
01-02 came with upgraded oil pump too didn't they?
Good catch. I've been looking for the Year change thread, but havent been able to find it.
**Edit here is the list**
https://ls1tech.com/forums/new-ls1-owners-newbie-tech/213148-jrp-s-faq-commonly-asked-questions.html
