lS6 in 01 Camaro
Motor cracked from dowlpin to the deck about a 1/8 inch thick. We talked to Scoggin-Dickey and said the trans would break first which would make since, hopefully they will warranty it.
Well that sure does explain unusual. I know those dowels fit tight but not THAT tight.
FWIW I have an '02 SS with a factory installed LS6 block, I did an M6 swap and used a dowel pin that was in the trans, trans was out of a '00 SS. The dowel fit just like the original.
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
