jus Ported my tb and the throttle sticks a little
Moderator
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
I did, and if you have a cam it needs to be drilled to 3/8"
and not the smaller holes you may see recommended in
some of the older How-To writeups.
For sticking blade, try loosening the blade screws slightly
and let the throttle snap shut (self-centering the blade)
then tighten in place. Then use the stop-screw to keep
the blade from resting against the casting, quite.
do u mean the hole in the throttle blade ?
