heads/cam hp gain??
You have a blower and need to know about heads/cam? I ASSUME you bought the car like that? Or didn't do any research before you bought the blower? Not to come off asd a smartass or anything,but If I were goin to slap down $5g's on a ProCharger I would have done some research.
Basic Knowledge tells me this topic has be discussed many times and could be found w/ a few quick key strokes in the search function of the site.
BTw..This is the wrong section for asking a question like this.
Also your goin to want a blower specific cam for the pro charger, a MS4,T-Rex ect are not the proper match for a boosted set-up. the LSA is wrong etc.
As for Heads Cam... My main concern would be saving up to build a stronger bottom end. You start putting alot of power through that stock short block,and Heads/Cam will be the least of your concern
Good Day and Good Night
my fault for thinkn somebody would actually help me out instead of tryin to make me look stupid. I was asking how much horsepower gain would i get from heads and cam brain buster. Dont reply if you dont answer the question... and also dont reply if your going to poss. **** somebody off. GOOD NIGHT GOOD MORNING!!
Well I did help somehwat..I told you to get a blower specific cam
Every car is diffrent.
BTW...its all in the tune...get a good tune,and not a hand held..
As I said before..posting this in the correct section will net you better results
