fbody rear seat delete
I took mine out years ago. Saves like 30lbs and actually makes the car MORE useful. Even with the 10lb nitrous bottle behind the passenger seat, I have put all kinds of stuff back there...
looks pretty good in the pic in the other thread. i took out the buckets but i couldn't figure out how the hell to get the other set out lol.didn't do to much exploring though
By any chance that one of you dudes knows what these covers are made out of?
I am seriously leaning this way, as I've had no rear seats in my 99' since it was new. They were nothing more than mock up foam inserts any way.
Thanks
Thanks
I took the rear seats out of my Z28. Not to save weight (the entire rear seat assembly is like ~10lbs) but rather because I converted to leather front seats, and could not find anyone selling just the rears
You guys should MAKE your own. Don't pay someone $100 for something you sort of like. You can make it with a simple jigsaw, a hammer, some nails, a razor, plywood and carpet.
I went to Lowe's and bought a big sheet of that blue insulation foam. With my rear seats removed, I sat in the car with the foam and razored it away until it meshed up nicely with the sail panels. That's the easiest way to make a template, IMO. Then I made the bottom piece (that straddles the driveshaft hump). It butts up to the top piece at a 90 degree angle.
I used half inch thick plywood. It weighed 5lbs-10lbs and was very easy to move in and out. I could also throw heavy stuff on it without worrying. I found some automotive carpet that 'sort of' matched, and got some of that dye spray from auto zone and painted it to match my interior.
It took about $30 and an afternoon to do. I liked it. Also the nice thing about doing it yourself is that you could customize it any way you want (for speakers, a bottle bracket, etc).
I like the way yours is a complete rear shelf instead of just inserts.
#32
Looks good man... I like the full cover of the set up, instead of the crap 89 dollar per insert that doesnt even look right.
Nice job setting that up.
#34
I did this back in the day. I would dig out some pictures but my old computer is in storeage.
I basically built two boxes (one for the passenger side and one for the driver side) out of 1/8" wood, then wrapped it in carpet. I tought it looked pretty nice. Have to say it does not really save much weight though.
#35
Weight savings are next to nothing. Unless you're looking for another .003 off your time, don't bother. If you just want to use it as an excuse, it's perfect for those you want to keep out and don't know better.
Anything you put back to make it look better will weigh as much as what you took out.
#36
I'm taking my seats out and putting in an eight point roll bar over the winter. So after thats in I will make something that cleanly wraps around the bars. But just high enough to make it flat because in a couple years i want to put some nitrous bottles on either side! I'm thinking two 15 pounders!!! Thats a ways off
