Bought a garage queen... do I mod or keep stock?
Location: Way Out In The Boonies Chasin' Hill Billies, North GA
You could always set your numbers matching 14k mileage engine off to the side of the garage under cover and replace w/ another to mod. LS1's have gotten cheap...
I have an 01 Camaro SS with 14,000 miles on and i'm making the following modifications:
Dynamat
Valve covers
200 mph gauge.
LG Motorsports G2 harness bar
Harnesses
Install 4 gauges
Triple Gauge Pod For T-Tops
AFR 205 Heads (ported by tony @ afr)
Nick Williams 90mm Tb (ported by tony @ afr)
Fast 90 intake manifold (ported by tony @ afr)
Comp Cam custom grind (224-228 on 114+2 lsa) possibly a 230 (tony @ afr)
Comp Pushrods 7.4”
37lb injectors used
Underdrive pully
LS2 timing chain from GM (chain and gears kit (cam gear) (tony @ afr)
Arp head bolts (unequal length)
Dyno Tune
Fuel pump (racetronix fuel sytem w/voltage booster)
Be Cool radiator w/electric fans
Long Tube Headers (probably kooks)
McLeod Clutch
Slave Cylinder 98-02 f-body
Hurst short throw shifter
Lower control arms rear
Eibach Front & Rear Sway Bar
Y-Pipe (possibly true duals/2 xr1 borla mufflers through x pipe and out borla dual dual tips)
Hotchkiss strut tower bar 98-02 f-body
Hotchkiss subframe connectors 98-02 f-body
Moser 9” Rear End
4 Channel ABS
Edelbrock torque arm (adjustable) for 93-02 f-body?
Custom Driveshaft (PST 93-02 F Body 3.5 aluminum driveshaft with 1350 yoke
Borla Catback Dual Dual Exhaust System
ZR1's
P-Zeros
K & N Cold Air Intake
Koni Shocks
Panhard bar
EiBach Pro Lowering Kit
Ram Air
rotors and pads.
Dynamat
Valve covers
200 mph gauge.
Harnesses
Install 4 gauges
Comp Pushrods 7.4”
37lb injectors used
Underdrive pully
Dyno Tune
McLeod Clutch
Moser 9” Rear End
4 Channel ABS
ZR1's
P-Zeros
Koni Shocks
Panhard bar
Ram Air
rotors and pads.
I bought my car with 25k on it. I only wanted a cat back and it has kept rollin from there. Id say go for it. Just keep all of the original stuff. Thats what I do. And I rack up the most miles drivin it to the track every once in a while. Otherwise it just sits and goes 30 miles here and there.
#33
Don't get a high mileage and expect it to last long with a new cam. Your internals will begin to wear and you will need to forge the internals very quickly. You may want to just keep her the way she is. Although you are on a MODIFICATION site afterall.
#34
The car in my sig. is being modded. I had a big thread about in when i got it back in June. Everyone convinced me that you only live once so you might as well have your car just the way you want it. No sense in savin it for someone else while we jus keep getting older and older...
#35
like the others said, mod it, and keep the stock parts so that if u you ever sell you can bring it back to stock. my dad bought his '01 cobra (hes still pissed that they added the s/c in 03) new off the floor and its only got 6k miles on it completely stock. ive been trying to get him to do minor mods to it, and keep the stock parts.
#36
LS1Tech Administrator
Received 1,684 Likes
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
I have a lower mileage (for the year) LS1 car than yours. My '98 is at 14k miles, and is staying stock (other than lid/catback). My 72k mile '02 car will eventually wind up heavily modded.
#37
This site is FULL of cam and heads/cam cars doing just fine without forged stuff.
#39
If you choose your mods wisely (driveability) and don't be cheap when it comes to doing it right then I say mod away and enjoy the car even more. They're awesome from the factory but they only perform better and better.
