General LSX Automobile Discussion Non-technical LSX related topics.
Instrument Cluster
Old Dec 3, 2007 | 03:57 PM
Beo's Avatar
Beo
Default Instrument Cluster
I was wondering, how different are the instrument clusters from a C5 'vette from a 4th gen fbod? I would like to have a 200 mph spedo, but don't really want to use a pod set up. Any info on the specs, what I would need to do for a conversion, or and other advice would be much appreciated.
Old Dec 3, 2007 | 04:00 PM
Ls1CamaroGuy87's Avatar
granatellimotorsports.com has 200mph speedos that fit our cars perfectly
Old Dec 3, 2007 | 04:11 PM
Beo's Avatar
Beo
Those look incredibly cheesy, imo. Thanks for the info though
Old Dec 3, 2007 | 05:20 PM
ROCNDAV's Avatar
Really? I think they look very factory. I was thinking of getting one myself.
Old Dec 3, 2007 | 05:40 PM
Beo's Avatar
Beo
Yah, unless they could give me the same exact style as I currently I have in my T/As, they look cheesy. Thats probably because I am not a big fan of the camaro instrument cluster for the same years...
Old Dec 3, 2007 | 07:35 PM
^^looks like you are screwed then, no one makes 200mph speedos in "firebird" style. I do not see how they look "cheesy"? its not like they have flames all over them or some ****....to each his own i guess
Old Dec 3, 2007 | 08:04 PM
RE AND CHERYL's Avatar
OMG! they are bad ***. I have to have one. I wonder if the wife would get one for me for christmas.
Re'
Old Dec 3, 2007 | 08:09 PM
Beo's Avatar
Beo
True, but the vette ones are almost as sexy.
Old Dec 3, 2007 | 08:14 PM
vaticano's Avatar
i got one looks just like the stock one, except for the white face, and the TCS says ARS. it's just an overlay with a little board soldered to the back of the cluster. you could probably make one glue it on and just adjust the computer calibration. lol
Old Dec 3, 2007 | 08:26 PM
Beo's Avatar
Beo
Good Idea, but im lazy. Might try that though.
Old Dec 3, 2007 | 08:43 PM
WRONG....Doing that won't work because adjusting the PCM calibration to make the speedo read right will throw off the odometer.
Re'
Old Dec 3, 2007 | 11:48 PM
PhantomR/T's Avatar
i love the vette's dash/guage cluster. I was throwing around the idea of swapping one into my car if I magically got a bunch of money
Old Dec 4, 2007 | 03:13 AM
Beo's Avatar
Beo
Due to the lack of response, I'm assuming no one has done this swap yet. Heh, I might have to be one of the first.
Old Dec 4, 2007 | 05:46 PM
vaticano's Avatar
Re'
then you can do this
"If this calibration is set to "Yes", the PCM will ignore the calibrated VSS settings and will use externally programmed VSS settings instead. That means an external scan tool (such as Tech2) is required to program the VSS settings.
If this calibration is set to "No", the PCM will use the calibrated VSS settings and will ignore any externally programmed VSS settings.
Only the following values may be entered into this table:
- No
- Yes
or maybe you can adjust the rear axle ratio to compensate.
this says it only changes the speedo
"The number of pulses the speed sensor produces per mile.
This value is used to determine the vehicle's road speed and therefore controls the speedometer needle in the instrument cluster. Increase this value to retard the speedometer needle, decrease this value to advance the speedometer needle.
It is calculated from tire size (T), H0102 (P) and H0103 (D) using the equation:
Pulses per mile: H0101=P*D*63360/(T*pi) where T is specified in inches.
or
Pulses per km: H0101=P*D*1000000/(T*pi) where T is specified in mm.
For automatic vehicles, it will normally be consistent with the equation: H0101=H0102*H0104.
Some vehicles, particularly those fitted with non-standard wheels or tires by the dealer, may not have this value set correctly. The speedometer may have been recalibrated in the instrument cluster to compensate for different tire sizes or diff ratios. In that case, the EFILive speedometer calculator may not calculate the settings for your vehicle accurately.
