General LSX Automobile Discussion Non-technical LSX related topics.
which oil do you guys use
Old 12-06-2007, 03:15 AM
wildn347's Avatar
Default which oil do you guys use
i currently run mobil one in my 98 ta and was wondering if royal purple or ams oil is a better choice or are they all about the same, i have talked to ppl who perfer mobil one then ppl who perfer royal purple, and ppl who like ams oil .... what do you guys think???
wildn347 is offline
Old 12-06-2007, 03:19 AM
wickedbusa's Avatar
I use Pennzoil Platinum in my Trans Am, and Royal Purple in my blown SS. I only use Royal Purple in my SS since the previous owner used it. Pricey, but I think it's worth it, especially if you are seriously modded. For a DD with mods here and there, I think either Mobil 1 or PP will do.
wickedbusa is offline
Old 12-06-2007, 03:28 AM
99mongooSS's Avatar
I ran mobile one until I went with the head and cam then I switched over to redline oil
99mongooSS is offline
Old 12-06-2007, 03:30 AM
Cvaught's Avatar
New Castrol Syntec 10w-30
Cvaught is offline
Old 12-06-2007, 03:59 AM
cookba's Avatar
german castrol 0w30
cookba is offline
Old 12-06-2007, 06:04 AM
toneloc60's Avatar
I switch between Royal Purple 10w30 and Pennzoil Platinum 10w30. I go about 2 oil changes with Pennsoil to every one of the RP. The RP has more detergents and is a very good oil for treating your seals and removing deposits while the Pennzoil is a better lubricant. The used oil analysis shows the Pennzoil to be just as good as Mobile 1 while it's quite a bit cheaper.
I go with a little bit thicker oil due to it's ability to resist breakdown. The only reason manufacturers go with 5w30 is to aid the MPG and keep the EPA happy. the 10w30 offers better protection without clogging.
I've got 108,xxx miles on my LS1 and she still runs like new. I don't even have the piston slap on start up I hear on many other LS1s. I figure I'm doing something right.
Oh, and I run RP throughout the rest of my driveline (2000 Z28, M6).
cookba, where can I order the German Castrol.
toneloc60 is offline
Old 12-06-2007, 06:50 AM
KrazyDan's Avatar
German Castrol can be found at autozone. They stopped making it so it is pretty hard to find. If you search hard enough you will probably find some though. Make sure it say made in grmany on the back
KrazyDan is offline
Old 12-06-2007, 10:26 AM
jebuzws6's Avatar
Mobile one all the way
jebuzws6 is offline
Old 12-06-2007, 10:38 AM
SchultzLT1's Avatar
Pennzoil Platinum 7.5w30
SchultzLT1 is offline
Old 12-06-2007, 11:16 AM
4150's Avatar
I'm using German Castrol for now, I'm not looking forward to the day when I can't find it anymore.
4150 is offline
Old 12-06-2007, 01:16 PM
The Black Mamba's Avatar
Lots of people use GC from what I've seen on this forum. I like Royal Purple myself though...
The Black Mamba is offline
Old 12-06-2007, 01:25 PM
SSmokin99's Avatar
I heard some good things about the Pennzoil Platinum. I think I might try it...
SSmokin99 is offline
Old 12-06-2007, 01:28 PM
seawolf18's Avatar
I use Castrol Syntech in mine. Have no problems and she runs quite.
seawolf18 is offline
Old 12-06-2007, 02:15 PM
2_wacko's Avatar
Mobil 1.
2_wacko is offline
Old 12-06-2007, 02:19 PM
WhosNXT's Avatar
German Castrol. But as others have said it wont be for long.
WhosNXT is offline
Old 12-06-2007, 02:33 PM
PLucas's Avatar
Search, many threads on it
PLucas is offline
Old 12-06-2007, 02:46 PM
02gtp4now's Avatar
i use rotella with my solid roller setup
02gtp4now is offline
rk_2000_Z/28's Avatar
Royal Purple 5W30
rk_2000_Z/28 is offline
Old 12-06-2007, 02:48 PM
SSlow1's Avatar
Royal Purple here 5W30
SSlow1 is offline
Old 12-06-2007, 03:39 PM
HandsomeBWouderful's Avatar
Castrol GTX or Havloine 10w-30. I don't run extended OCIs so I will run the dino based stuff without a second thought. I do spluge for a decent filter - Purolator or WIX. (the long filter used on GM trucks)
HandsomeBWouderful is offline
