Thermostat question?
Well as of right now i live in Hawaii so I dont have to worry about the cold. I heard if I just get my fans to come on at a lower temp I should be good? True or no?
it would be ok to go with a lower temp Tstat but in order to make sure it operates the way it should you need to reprogram your fans for the new T stat. Now if you add a 160 T stat and leave the fans alone will it blow your engine? No but it wont be operating together the way it should
