I believe I'll switch to LS1 form LT1
but you would have to deal with water going in in case you drive into an invisible puddle until its too late, and it may cause arcing causing the spark to escape from thoes cylinder terminals close to the hole.
Good Luck man, I'm going that route here in a few years. I want to build the LT1 and then when it's all said and done. I'll pick up an LS1 cheap and do it the same way. They are by far the superior motors. Good Luck again. You won't regret it at all.
Especially when you compare the most bang for the buck as opposed to the LT1's bang for the buck modifications
thanks guys.....and for 96mikez28 if that was sarcastic then I am a 17 year old who is in high school and works 2 jobs. Almost every penny I got went into paying for my car or doing stuff to it. In 2007 it got a whole new rear end(almost 1000 bucks) a new transmission(close to 1500 bucks) and new plugs,wires, front lca bushing, and an alignment(over 500 bucks) plus a couple other small things.
What I should have said was if interested in the idea do a search to find out more than the hearsay from me, but the concept is out there.
Since the guy's brother is having the problem I think he said, here ya go.
this wasn't the one I read, but actually goes into more detail...
https://ls1tech.com/forums/showthrea...rill+optispark
