need some feed back on what i should do here, LS1, LS2 OR LSX OR Warhawk BLOCK
Well im going to build a LS style engine when i sell my 406 ci. Now im thinking on going with a LS1 OR 2 block and doing the machining and all the work, the other is get a LSX block and build that up OR run warhawk block with a set of 12 degree warhawk heads 285cc. i really dont now yet, I like the Warhawk stuff quite abit. Looks to bee very nice stuff, The plan on this motor is to get around 1000+ HP forced induction of course on 93 oct. Going to run a Pro Charger On her. This engine is going into my Pro Touring 1992 CAMARO. I figured its going to be better for street driving with the LS style engine...
no offense but you only waited an hour. secondly if your going to do it correctly just get a good ole iron block and call it a day. go look in the forced induction area. make sure you have all the fuel and everything else to go with this build. good luck
I will have plenty of fuel, this car is hand built by Me, I build cars for a living, and its just a first build up of a LS STYLE ENGINE. full chrome moly chassie, I built a 406 small block for this car, and was going to be FUEL INJECTION. But decided to go with the LS STYLE engine and some Forced Induction, I normaly use Turbos, but want a procharger on this car. Try them out. planning on running a TH 400 WITH a gear vendor also, Ill look into the Iron BLOCKS...... I was looking at ALUM because of weight savings,
