General LSX Automobile Discussion Non-technical LSX related topics.
What coolant??
Old 01-22-2008, 05:18 PM
FNQUIKWS6's Avatar
Default What coolant??
Does it really matter if you use regular green coolant versus the orange stuff?
What are your opinions?
Old 01-22-2008, 05:27 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Exclamation
Orange is best....all Orange coolants say GM/Dexcool Compatible...others disagree..give it 2 minutes.
Old 01-22-2008, 05:30 PM
CranMaro99's Avatar
Dexcool.
Old 01-22-2008, 06:34 PM
ReFtheMC's Avatar
Haha, i was actually just wondering the same thing...
Old 01-22-2008, 06:38 PM
'Bird Director
y2k_ta's Avatar
Location: Central Indiana Honors: 4th grade spelling bee contestant
Prestone makes a version that is compatible with both green and orange.
Old 01-22-2008, 07:30 PM
foreverzero's Avatar
+1 on Dexcool for me....but i heard that if you mix it with more water than coolant it keeps the engine cooler. Also has anyone ever tried the royal purple stuff you put in with your coolant? ...supposed to drop the temp pretty good
Old 01-22-2008, 07:32 PM
NHRAMAN's Avatar
Lightbulb
Yeah..someone said that before..we don't have it...at least where I looked.
Old 01-22-2008, 09:21 PM
01CamaroZ28's Avatar
yea i use the prestone mentioned above
Old 01-22-2008, 09:25 PM
Spiers's Avatar
I heard Dexcool was crap, I run the green stuff. LT1
Old 01-23-2008, 01:05 AM
waldershrek's Avatar
You can run either one just don't mix the two. Get it flushed and replaced with one or the other.
Old 01-23-2008, 08:09 AM
BlackBADaSS02's Avatar
I run the orange dexcool.
Old 01-23-2008, 09:18 AM
Sharpe's Avatar
As far as I know, in all vehicles, from big disel duallies to little Honda civics, you need/want a 50/50 mix of coolant to water. Someone will correct me if I'm wrong.
I buy the cheapest, already mixed stuff I can find.
Old 01-23-2008, 09:22 AM
97greenie's Avatar
I use only the dexcool per the owners manual.
Old 01-23-2008, 09:24 AM
cookba's Avatar
i have been using the G-05 coolant for a few years, and i dont see any problems with it. I did a full flush (a couple times) and then filled up with it. Some of the auto x guys use it too
Old 01-23-2008, 10:00 PM
ghardester's Avatar
I believe this advice is correct. But this subject is like spark plugs or air filters, there are strong opinions. I use Dex.
Old 01-23-2008, 10:08 PM
Rushin's Avatar
Using more water than coolant will make the engine run slightly cooler, but it might cause some reliability issues down the road. Water does things to aluminum. My friend got a small leak in his radiator and used straight water for 4 months. After we replaced it, I cut open the old one and showed him why it sucks to run 100% water.
Old 01-24-2008, 10:36 AM
Rowin Gearz's Avatar
I use the premixed dexcool stuuf. Hasn't let me down yet.
Old 01-24-2008, 06:32 PM
sleepinghawk's Avatar
I used the green Prestone that was compatible with either one for a while in the Hawk. Then decided to just change out my coolant every year, but stick with the orange drex. Yea I know it's a waste but that's me when it comes to my cars.
Old 01-25-2008, 09:57 AM
JTH2000SS's Avatar
I dont know which is better, but when i bought my raditor radiator they would only warranty it if i used the orange stuff in it
Old 01-25-2008, 10:05 AM
kokingSS's Avatar
dex-cool
