Any advice on best subframe connectors for ground clearance?
Ok, I have a question. I just followed the link and looked at the sub frame connectors. I'm looking at the bolt in, simply because I don't have a welder, but still prefer doing the work myself.
So, what is the difference between the tubular style, and the 3-point style? Besides the price.
Thanks.
Thanks.
Thanks for the interest
We recommend the 3-Point style for the serious racer and/or if you are running a short tunnel mounted torque arm. When running a shorter style tunnel mounted torque arm the 3-Point SFC's bolt under the torque arm and reduce the stress the torque arm applies into the floor of the car. Here is a picture to reference what I am referring to- http://www.umiperformance.com/images/2004b.jpg
If you have any additional questions please ask. Thank you!
Ryan
teh PuRpL3z
Hello,
Ryan
Ryan
I would DEFINITELY look into Spohn's SFC's.. I have a set and they tuck up against the floor... absolutely no loss of ground clearance... Plus they're tubular and come powdercoated... Can get them in 4130 if you'd like... You can even weld them without removing carpet... or you can remove the carpet and weld them the entire length of the SFC, to the floor...
As for their TA, there's a little loss of clearance with it.. I bang it on speed bumps every now and then...
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Is there any difference in ground clearance with the different styles you offer? I want the best but at the same time I'm trying to refrain from repainting the bottom of my car with speed-bump yellow.
