My new Build Bunch of PICS
you need better fuel rails. the ls1 fuel rails start to choke the motor at 600 at the fly. you will have no problem making that power you will most likely make more. get a 100mm MAS.
Im gonna get a SD tune... as far as fuel im trying to figure out what route i want to go with the fuel setup... im thinking about just getting the nasty setup that way all the parts will be there and i will not have to part it all together...
well i blew the tranny out while it was on the dyno 3rd pulll ughhhhhhhhhhh.... We where just strating to tune it lol........ so im in the process of trying to figure out what i wanna do there i was gonna go th400 but i think i like 4th to much to do away with it.... I also need to pick a new stall out the 2800 was to small,,,,,, i have a video and a dyno sheet ill post it here in a little while....
#32
3rd pull before the tranny went
inside idle vid
http://www.youtube.com/watch?v=UALqV3PzN5o
driving in the parking lot
http://www.youtube.com/watch?v=JNY5P3iORp0
Drive through the tunnel
http://www.youtube.com/watch?v=WTtBXsMGFYE
First Start up
http://www.youtube.com/watch?v=IjBLzapma9M
inside idle vid
First Start up
#38
got a ole 383 in mine. 5.3 heads, a4 with a 3600 stall and put down around 480 at the wheels. this car is a full weight street car with all the options.
Times in sig. My NA times are a 6.95 @ 98mph, 10.94 1/4. With timing pulled out for n20. beleive it or not, i have never ran the car with all the timing in it!
Your setup is gonna fly!
