17/18 rims confuse speed sensor?
i have the vette c5 17/18 wheels. it is how i bought the car.. the car also had the abs inop and brake light on in the dash. i was wondering if those lights would be on because of the different size wheels rolling at different speeds... 17's are 25" and 18's are 26".
any input on running different size wheels?
no issue.
that's not the cause of your problem. if the overall height of the rear wheel differs from that of stock, your speedo will be off, but it will not render the ABS inop.
My lgith would come on under hard braking with different size rear tires on
that has NOTHING to do with rim size. if the standover height of the slicks is different than stock by a bunch then that can have an effect.
if your sensors were in perfect shape, you would not be experiencing that issue.
((((((Administrator))))))
![Exclamation](https://ls1tech.com/forums/images/icons/icon4.gif)
![Stupid](https://ls1tech.com/forums/images/smilies2/stupid.gif)
Peace,
Craig.
LS1TECH & Trucks Sponsor
The difference between front and rear overall size actually IS what causes the light in situations such as this. The abs system can not do its job when the front/rear are spinning different speeds, because it doesn't know if you lose traction or not since the wheels are not all spinning at the same rate. If you go up or down in size, either front or back without the other, it will trigger the light.
In the OPs situation the fronts are too short, therefore spinning faster than the rears (which are the correct overall diameter/circumference), so his ABS shuts off.
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic3451_2.gif)
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
