General LSX Automobile Discussion Non-technical LSX related topics.
what mph is the sweet spot for the absolute best gas mileage for an a4?
Old 03-22-2008, 04:21 PM
  #41
LS1Tech Administrator
RPM WS6's Avatar
Received 1,789 Likes on 1,276 Posts
Originally Posted by quadd2244
X2 or buy a 6speed and throw a 2.73gear out back
I bet that an M6 + 2.73 would yield 34-35mpg cruising at 65mph in 6th.
Old 03-22-2008, 04:33 PM
  #42
quadd2244's Avatar
Hell yeah maybe GM can do that to solve the gas problem they have been talking about. You can buy a 6speed vette with the 2.73s then chevy automaticly will swap it out for free after the purchase ofcourse
Old 03-22-2008, 05:06 PM
  #43
KameleonTransAm's Avatar
Well obviously you reducing your speed will improve your gas mileage however, it will take you longer to get where you are going. So really, you are going to use the same gas going 65 mph or 55mph because it will take you that much longer to cover the same distance. On a side note, this thread is pretty funny and hopefully you got there safely!
Old 03-22-2008, 05:18 PM
  #44
Nickstock98t/a's Avatar
thanks for keeping me entertained guys. i got to my destination safely. it really didnt take that long cruising at 50-55. but i'll never do that again. i dont really think i saved all that much. but it was fun experimenting. thanks guys
Old 03-22-2008, 05:20 PM
  #45
2manycars's Avatar
It wouldn't get more than 30 and that would only be out in the midwest where everything is flat. Try that in the northeast and you wouln't see any difference because you can't drive around at 65mph w/under 1200RPM... doesn't work. Also people throw these numbers around but truth is 30MPG would be incredible in an LS1 F-body with any type of gearing.
Old 03-22-2008, 06:20 PM
  #46
RPM WS6's Avatar
Lots of M6 guys get 28-30mpg with stock 3.42 gears.
My A4 with 2.73s gets 26-27 on the highway, at 65mph.
Old 03-22-2008, 06:21 PM
  #47
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Talking
Originally Posted by Vicinity
But not best gas mileage.
Old 03-22-2008, 06:37 PM
  #48
99camarosupersport's Avatar
Originally Posted by Nickstock98t/a
I'm driving while surfing the web. I'm using an iPhone. I tend to multi task a lot. I'm at 65 mph 2100rpm with 3.23 I might consider cruising at 60 soon. Not real happy with the current mpg
Want good MPG? Get an M6.
Old 03-22-2008, 06:45 PM
  #49
Truth is 30MPG would be incredible in an LS1 F-body with any type of gearing.
I agree 1000000000%
Old 03-22-2008, 09:53 PM
  #50
Detoxx03's Avatar
Don't crash
Old 03-23-2008, 11:43 AM
  #51
2manycars's Avatar
Old 03-23-2008, 12:11 PM
  #52
JScamaro's Avatar
I know driving behind a semi truck can increase your mileage but your car will get murdered with debris and rocks in the process.
Old 03-23-2008, 12:18 PM
  #53
SladeX's Avatar
I've done some experiments for mileage at 65mph and 75mph covering the same distance and filling up immediately after the trip. Holding consistent speed 95% of the time using cruise control
There seems to be an efficiency similarity between the 2 speeds as I noted nearly identical mileage and fuel burned. When you take into account aerodynamics, between the 2 speeds, air drag is all that really differs. You're still just maintaining speed and using your engine to offset friction. Since at that low of a speed air drag isn't all that of a factor, it'll be pretty much the same.
What I did notice is IF I varied my speed, mileage went down.
Old 03-23-2008, 01:05 PM
  #54
Joshiedoom's Avatar
Gas Mileage goes down when abrupt deceleration or abrupt acceleration occurs
Old 03-23-2008, 08:42 PM
  #55
02Z28LS1's Avatar
unless you throw it in neutral when decelerating, which should save some gas
Old 03-23-2008, 09:51 PM
  #56
Joshiedoom's Avatar
I do on hills and such.
Old 03-23-2008, 10:34 PM
  #57
FMX05's Avatar
I go into neutral whenever I see a stoplight or stop sign. Not to save gas, but to avoid using my clutch more than I have to.
Old 03-24-2008, 01:54 AM
  #58
Finite1's Avatar
2.73's For.The.Win.
Wait, no... FTL
Old 03-24-2008, 05:46 AM
  #59
waldershrek's Avatar
This will sound retarded but try driving the speed limit. Try it, it works.
Old 03-24-2008, 07:09 AM
  #60
Says the cop.
Quick Reply: what mph is the sweet spot for the absolute best gas mileage for an a4?
