how much HP?
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
i dunno, the 99 cam is the very slightly bigger stock cam.
with mac mids, mac catted y, magnaflow catback, lid, my own hptuners tune i put down 336/339 on a dyno dynamics through my a4 on unlocked converter. my af was 12.6-12.7 all the way across.
however, if i put my car on a scale, i'd cringe at those numbers.
Cam specs are:
Stock 98-00 trans am cam
Duration@.050 198.86 intake 209.25 exhaust
Lift .498 intake .497 exhausts
LSA 119.45
Stock 01-02 trans am cam
Duration@.050 196.37 intake 208.72 exhaust
Lift .464 intake .479 exhausts
LSA 115.92
I'm not sure what your getting at with the "99's have bigger cam" but because 98-00 had the bigger cam doesn't nessesarily mean anything substantial as far as power. Good numbers BTW
ok so how much horse power do you guys think my car is going to be running.
its 99 z28 LS1
with long tubes
high flow cats
true duals
Fast toys lid
ported MAF
smooth below
ported and polished throttle body
LS6 intake
Underdrive Pully
and tuned?
my friend said he only saw 300 to 325hp? i said he was full of
what do yall think?
as of now its just all mods in sig but will hopefully have whats mentioned by summer. give me your opinions, thanks.
-Kris
its 99 z28 LS1
with long tubes
high flow cats
true duals
Fast toys lid
ported MAF
smooth below
LS6 intake
Underdrive Pully
and tuned?
![turd](https://ls1tech.com/forums/images/smilies2/turd.gif)
-Kris
98-00 has the same spec cam with crappy heads (806 853 I think), ls1 block, & crappy ls1 intake compared to later years. 01 & 02 has a smaller cam with better heads (841), blocks (some had ls6), & ls6 intake than the previous years.
Cam specs are:
LSA 119.45
LSA 115.92
I'm not sure what your getting at with the "99's have bigger cam" but because 98-00 had the bigger cam doesn't nessesarily mean anything substantial as far as power. Good numbers BTW![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Cam specs are:
LSA 119.45
LSA 115.92
