General LSX Automobile Discussion Non-technical LSX related topics.
engine removal
Old May 18, 2008 | 10:49 PM
noregretz999's Avatar
Default engine removal
can a ls1 motor be removed with the tranny from the top.
thanks
Old May 18, 2008 | 11:31 PM
9000th01ss's Avatar
Yes but you have to unbolt the K member and let it drop about three inches. Maybe taking the intake off would help.
I just put one in from the top and the intake hits the cowl. I had to jack the body up and drop the k member a few inches.
I've also pulled one right out with hood still on the car but the trans taken out first.
Old May 19, 2008 | 11:30 AM
thats what I thought guess Ill just take out the motor and tranny separately
thanks
Old May 19, 2008 | 11:58 AM
jsteele90's Avatar
just remove it from the bottom.
Old May 19, 2008 | 12:07 PM
landonew's Avatar
+1, bottom is much easier
Old May 19, 2008 | 12:09 PM
dont want to have to do that the car receiving the motor and tranny, sitting right next to the one that im taking it out of, already has the front suspension in so I want to be able to just drop in the motor+tranny
bjamick's Avatar
Pulled mine out the bottom is anout 3.5 hours ..
Old May 19, 2008 | 12:12 PM
Disturbed Bird's Avatar
no you dont need to drop the k member. i just took mine out last week. you need to remove the engine pedestal(what the engine mount connects to). and it will come right out with alot of room to spare. took me about 2 hours.
take off all the front engine accessories, take out the radiator, disconnect all wires
Old May 19, 2008 | 02:19 PM
you did this with the tranny attached?
Old May 19, 2008 | 02:31 PM
Silver6sp's Avatar
ive pulled them with intakes/headers off, radiator out and unbolting one motor mount....hood was on too
Old May 19, 2008 | 05:11 PM
yes i also took the intake manifold off everything else was left on
Old May 19, 2008 | 05:16 PM
9000th01ss's Avatar
Yea take it down to the long block it'll slide right in.
Engine pedestals out, the pan hits the K member, the intake hits the cowl, the front accessories don't hit anything.
Should rename this post "list 100 or more ways to remove an LS1"
Old May 19, 2008 | 05:18 PM
9000th01ss's Avatar
Oh, now thats a different story.
Like I said in the first post, and the second, it will hit the pan and the intake. You either need to take the intake off or drop the K member down. You don't need to remove the front accessories.
Old May 19, 2008 | 06:01 PM
crzytown69's Avatar
Drop It From The Bottom
