Another RPO question
It just seems odd to me that they would go to all the trouble of ordering a car with the 1SB and 1SD option group just to have all of the electronic stuff taken off. It seems like it would have been cheaper for the dealer to order an 1SC car. On a side note, are there many if any 1SC 1LE cars? Seems like they would have been the ultimate track car.
The other possibility that I was thinking about was, the car could have been stolen or heavily damaged and the doors removed and replaced my the manual doors. Did you ever do a carfax report to see if that was a possibility? The corners are peeled back on the SPID label. It is a very odd combination. There seems to paint overspray on the sticker and the seal.
I checked mine out and everything is as it should be, but still have no power options except rear defroster. Here is my RPO list, sorry it is so long.
AH3 : ADJUSTER, 4-WAY MANUAL, DRIVER SEAT
AK5 : RESTRAINT SYSTEM, FRT SEAT, INFLATABLE, DRIVER
AR9 : SEAT, FRT BKT, EUROPEAN STYLE, PASS A DRIVER RECL
C49 : DEFOGGER, RR WINDOW, ELECTRIC
C60 : HVAC SYSTEM, AIR CONDITIONER FRT MAN CONTROLS
DL5 : DECAL, ROADSIDE SERVICE INFORMATION
D35 : MIRROR, OUTSIDE REAR VIEW
FE3 : SUSPENSION SYSTEM, SPORT
GU6 : AXLE REAR, 3.42 RATIO
G80 : AXLE POSITRACTION, LIMITED SLIP
IPB : ?????????????????????????????????
J65 : BRAKE SYSTEM, PWR, FRT & RR DISC
K43 : ?????????????????????????????????
LS1 : 5.7L GEN III V8 ENGINE
MM6 : TRANSMISSION, MAN 6 SPD, BORG WARNER
MN6 : MERCHANDISED TRANS, MAN 6 SPD PROVISIONS
NB7 : ?????????????????????????????????
NGZ : ????????????????????????????????
NK3 : STEERING WHEEL, SPORT, SOFT RIM, SIMULATED LEATHER
N96 : WHEEL, 16 X 8, CAST ALUMINUM
QLC : TIRE ALL, P245/50ZR16/N BL R/PE ST TL HW4
R7A: ?????????????????????????????????
R8T : CONTROL, SALES ITEM NO. 69 PROCESSING OPTION
R9Z : ?????????????????????????????????
STE : ?????????????????????????????????
T82 : HEADLAMPS, AUTO ON-OFF CONT
UB3 : CLUSTER, INST, OIL, COOL TEMP, VOLTS, TRIP ODOM, TACH
UN0 : RADIO, AM/FM STEREO, SEEK/SCAN, CD, AUTO TONE, CLOCK AND ETR (RADIO WILL NOT SNAP FIT INTO I/P – NO ATTACHING FASTENERS)
UZ7 : ?????????????????????????????????
U73 : ANTENNA, FIXED, RADIO
VK3 : LICENSE PLATE, FRT MOUNTING PKG
VL7 : ?????????????????????????????????
Z28 : MERCHANDISED PKG, SPECIAL PERFORMANCE
1AZ : ?????????????????????????????????
1SD : OPTION PACKAGE 04
1SZ : ?????????????????????????????????
14B : TRIM COMBINATION, CLOTH, LT GRAY (B) (92)
141 : ?????????????????????????????????
41U : PRIMARY COLOR, EXTERIOR, BLACK
6ZL : ?????????????????????????????????
7ZL : ?????????????????????????????????
8TJ : ?????????????????????????????????
9TJ : ????????????????????????????????
I just hit camarosource.ca just to see if it would tell you what the 1SZ option is. All it comes back with is discount option code.
Here's the link I used.
http://www.camarosource.ca/php/camar...year=2002&tm=1
Thanks man. My friend at the dealership wasn't able to find hardly anything about my car from the VIN (he was going to get me a copy of the original build sheet) but he said it's not totally uncommon for older cars now. Sure doesn't feel old but I guess it's 9 years old already.
let me know
