can i install a cam?
Its also dependent on how large of a cam you put in. I would definitly be sure to upgrader my valve train, but these cars are good at high mileage as long as its been taken care of.
I might be a little scared of dropping a lifter when doing the install. the retainers may be a little loose with that many miles.
if you are planning on taking the heads off to put in new lifters anyway, then you will be fine.
(with that many miles I would highly recommend replacing the lifters anyway)
