General LSX Automobile Discussion Non-technical LSX related topics.
M6 people, when you park Ebrake or leave in gear?
Old 07-25-2008, 12:57 PM
  #101
99Hawk6spd's Avatar
I did neither once in my explorer !DOH! rolled into the middle of the burger king parking lot, and didn't hit a thing. Kind of embarrasing having someone walk into BK and ask if someone there owns the explorer that just rolled across the parking lot. Moral of the story, don't get distracted when parking your vehicle.
Old 07-25-2008, 05:11 PM
  #102
Black 99 Bird's Avatar
e-brake only here.
Old 07-25-2008, 05:58 PM
  #103
95 Z28's Avatar
Neutral + E-brake for me.
Old 07-25-2008, 07:14 PM
  #104
_JB_'s Avatar
Gear+E-brake
Old 07-26-2008, 10:22 AM
  #105
01ssreda4's Avatar
cant leave my DD in gear if i wanna use the remote start so its left in neutral. if there is any question about the incline i set the brake. at work i dont set it bc the incline is towards the parking block, so i just rest the tire against it and usually dont set the brake.
Old 07-26-2008, 11:07 AM
  #106
foreverzero's Avatar
If the car is facing uphill, E-brake + 1st, if it's facing downhill, E-brake + Reverse. Otherwise I don't put it in gear
Old 07-26-2008, 09:22 PM
  #107
bricez28's Avatar
just my ebrake. when someone else drives it they leave it in gear and i almost die. my ebrake is pretty good. usually my cars in my garage anyway.
Old 07-26-2008, 09:29 PM
  #108
tpduke112's Avatar
I do both. First gear.
Old 07-28-2008, 01:44 PM
  #109
TLUZLS1's Avatar
I do both.....
Old 07-28-2008, 09:30 PM
  #110
mukyluk's Avatar
both. the gear acts as a back up incase the ebake cable breaks for some reason. and vise versa, the ebake holds the car incase for some odd reason it pops out of gear when parked, or something just lets go
Old 07-28-2008, 09:43 PM
  #111
Vertigo's Avatar
Just 2nd
Old 09-19-2008, 05:26 PM
  #112
Tyler_LS1's Avatar
Always use the ebrake and some times i will do both
Old 09-20-2008, 03:55 AM
  #113
KFC_Or_Bust's Avatar
So where do you work again? Love to come and push your car elsewhere and then have you wonder how it could possibly have gone anywhere!
Originally Posted by defenestrate
both, but i pull the ebrake first and and let off the brake with the clutch in so the weight isnt bearing on the trans.
Same here, like clock work. And when I get back in I do the following steps EVERY time:
1. Right foot depressing brake pedal
2. Left foot depressing clutch
3. Right hand letting down e-brake
4. Right hand starting car
5. Right hand on shifter and off we go...Unless Reverse is needed of course! Or vice versa.
If I'm starting and not moving immediately then step 3 would be removed and step 5 would be taking the shifter out of gear and slapping it back and forth a few times to ensure it isn't still in gear before I let my foot off the clutch and brake. Why put my foot on the brake if I'm not going anywhere? Habit mostly and partially because I don't like the weight of the car falling back on the brakes harder than necessary. Or the transmission for that matter.
Old 09-20-2008, 02:48 PM
  #114
proporio's Avatar
E-brake and in gear
Old 09-20-2008, 03:08 PM
  #115
ae13291's Avatar
e brake and neutral here. unless im on a uphill or downhill then it goes into 1st gear. this should have been a poll
Old 09-20-2008, 04:07 PM
  #116
i3oosted's Avatar
Only ebrake unless on a STEEP incline/decline. I don't know how many times someone has driven or moved my car and left it in gear, then I go out and start it only to have it learch forward saved by the ebrake from going over curbs or through walls, lol.
Old 09-20-2008, 04:39 PM
  #117
landonew's Avatar
Exacly my thoughts. I Don't park my car on step slopes, and the E-Brake should be fine for flat surfaces. Also, if you get towed I would rather replace my ebrake then my drivetrain.
Old 09-20-2008, 06:12 PM
  #118
mike#9's Avatar
I use both always
Old 09-20-2008, 06:26 PM
  #119
razorclaw99's Avatar
both just incase
Old 09-20-2008, 06:27 PM
  #120
406malibu's Avatar
not this thread again....
Quick Reply: M6 people, when you park Ebrake or leave in gear?
