Iron block vs. Aluminum block
me and another guy at my college today were talking about cars of long story short we got on the talk of block strength. we both agreed that it is widely accepted iron blocks are strong for boost, nitrous, etc. now what we really didnt know was whether a forged bottom end on an aluminum was just as good as a FBE iron block, under non-extreme power (i.e. 800hp and below). i would assume that, duh, the iron block is stronger but i really didnt know when the differences REALLY start to show/matter. anyone gimme some answers. i know its broad but answer in your expertiece
dont ridcule me, just trying to gain info. sorry for the newb-ish question thanks in advance.
A main girdle is like backup for the main bearing caps, keeps them held down. Just like a rear end girdle presses on the bearing caps to keep the ring gear/differential still.
Iron block is stronger, but slightly heavier (80lbs). It doesn't require sleeves so it can be rebuilt a number of times. For sub 800rwhp, a girdled alluminum block is ideal.
Whether an iron block is significantly stronger than an alliminum block is questionable. Some claim that aluminum blocks are plenty strong and with a good tune (i.e. no detonation) they are capable of 1300rwhp+. Others claim that Iron lq9 block has a clear structural advantage. I have no opinion on this matter.
Now the LSX iron block (gm performance block) is clearily the strongest but also very heavy. The warhawk alm. block is also a nice piece.
If they use the same tooling during the casting of the two blocks, iron and aluminum, the iron block will be far superior to the aluminum block. You will be able to dyno both built engines and notice missing horsepower at high levels due to the block shifting and creating out of round cylinder bores.
A good manufacturer will have additional reinforcement and add structural rigidity to the block by adding ridges and beefing up certain known weak spots in the block.
