Gnx Rims!!!!
GNX wheels won't fit....the bolt pattern is probably right, but the backspacing is way off. They'll probably stick way out.
Check all the usual wheel places, maybe you can find a wheel that looks similar, but larger. I think the GNX wheels were only 16x8.
GNX wheels will not fit your fbody, and im almost sure the bolt pattern is even different, but you may check the 89 turbo TA wheels, they will probably bolt up, but as stated before, the backspacing is different. not the most common wheel swap, so may be difficult to find some that will fit.
Look at the wheels from the Year One, they look very similar with the honeycomb design.
http://www.yearone.com/serverfiles/f...ain2.asp?cat=G
