Spark Plug Wire Question
It is the second plug from front to back on the drivers side. I believe it is plug # 3 I removed it and it was loosely attached to the block. The firing tip has greyish white deposits and it gapped @ 0.055 ". I will place it back on the block and make sure that it is a little tighter than what it was. Should I be concerned? What do you all recommend.
i would just replace the plugs and wires, heres a good special on msd wires and ngk tr55 plugs http://www.texas-speed.com/shop/item...d=922&catid=11
