SFCs & drive thru car washes
I work at a Dodge dealer so I can get a good hand wash whether I do it or the new car cleanup guy does it. If I am busy enough working, its cheaper just to pay the cleanup guy $10 to wash it. On Sunday, cant do that & didnt plan on driving the camaro to work much this week so it ended up being a waste of $7 tryin to get a quick wash at this particular car wash. I am so glad my car is not lowered, it sits low enough as it is. I was visiting mom & dad in Clio on Sunday so I went to the car wash right in town by the RR tracks. I am sure you know which one I am talking about. I actually worked at that same car wash 5 years ago for a very short time. It was much nicer then. The place has really went down hill bad since then. They wont be open for long the way theyre doing things. BTW, I am actually from Clio, but live in Mt Morris.
I went through a touch less car wash once when i was in a hurry, never again! You might wanna check your lower control arms if you have aftermarket ones with relocation brackets even at stock height. It snapped the grease fitting clean off on my car and was a PITA to fix.
It's all in the pressure on the water. High Pressure Water will force some of the dirt on your car into the clear coat and into the paint, like little bits of sandpaper. Some ******** kid at a dealer blew the clearcoat right off my bumper using the same type of "gun" as the DIY Car Wash that uses like $1.50 in quarters. General rule of thumb to remove dirt is just to use a garden hose with no nozzle on it at all and let the water "sheet" it off. While I do think using a garden hose with a regular sprayer on a "light" setting is not too bad, using a HIGH PRESSURE water gun is suicide for paint job.
I have used an auto car wash 3 times on the Camaro. 3rd time was after I lowered it and the Y pipe got hung up on the rails. It bent the Y pipe a little getting the car off. The car wash people weren't very nice either. Something along the lines of get out of the way, see all the business backed up behind you. Needless to say Rain Tunnel Express will never get any business from me. I hand wash all 3 of my vehicles after that.
Whatever happened to Hardcore Motorsports anyway? It was on Clio Rd.
Yeah i know which one your tlaking about. My dad took his car there for a wash and they did a real shitty job and were rude about it. It used to be nice a long time ago... but like you said it went down hill.
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
#32
Some high pressure sprayers or powerwashers that you buy at a Lowes or Home Depot are actually too high pressure to wash cars & can do damage to the paint. Somewhere in the 3000 psi range. Most car washes do not use these high pressure sprayers. Car washes use somewhere in the 1500-1800 psi range. The key is dont get the nozzle real close to the finish when rinsing the car. Hold it back a few feet & you wont have a problem.
