Sponsored by: CARiD
camshaft??
Old Oct 18, 2008 | 09:30 PM
jlincks's Avatar
Default camshaft??
to install a camshaft into a 94 firebird do u have to raise the motor outa the car or is there an easier way?
Old Oct 18, 2008 | 10:08 PM
TireSm0ke's Avatar
You dont have to remove the motor. Youll need to move/drop the condenser and radiator but its been done many times with the motor in the car. ls1howto.com has a good writeup, check it out
Old Oct 18, 2008 | 10:26 PM
jlincks's Avatar
do u hav to change the coil packs over too win u put a cam in?
Old Oct 19, 2008 | 12:46 AM
Formula413's Avatar
What coil packs?
Old Oct 19, 2008 | 11:27 AM
twitchtwice's Avatar
lt1's dont have coil packs
Old Oct 19, 2008 | 02:37 PM
TireSm0ke's Avatar
You have a distributor on your LT1 buddy. No coil packs. Even if it were an LS1, the coil packs dont need to be changed. You need to remove them to pull the valve covers to hold up the lifters.
Old Oct 19, 2008 | 09:26 PM
jlincks's Avatar
i didnt mean the coil packs i ment the springs? do that come w the cam?
Old Oct 19, 2008 | 09:49 PM
Formula413's Avatar
It may or may not but you will need them with a new cam. Check out this thread for lots of info on cams. It deals with LS1s but a lot of the info is relevant to LT1s as well.
Old Oct 19, 2008 | 09:54 PM
Slvr00Bird's Avatar
Do more research.. much much more..
Old Oct 20, 2008 | 08:27 PM
coolformula's Avatar
Always a good idea to get some springs..that can hold the it together.....dont' skimp. New oil pump not a bad idea. Pull the radiator all that, should be able to change it without pulling the engine..
Read and search a lot...if your having these type questions..might be better to pay a local shop or a sponsor(not trying to be mean)
