Sponsored by: CARiD
LS1 TA Static Battery Drain
Old Oct 20, 2008 | 03:40 PM
J-Train's Avatar
Default LS1 TA Static Battery Drain
Well, my cars doing it too, and its driving me nuts, I searched through the numerous, and I mean numerous posts about this and have yet to find anyone that actually figured it out. I have read all the directions on using the amp meter in between the positive and the bat and removing fuses one by one, but no one has ever posted up that they fixed it.
I have been through two optimas, just to make sure I did not have a bad battery, the only aftermarket item I had on my car, a US spec ipod adapeter, has been isolated, and its still draining about 1 volt per 24 hours.
On my volt meter it is reading more tha 2 mA draw, but on the 20mA setting it is reading nothing
Has anyone figured it out It has got to be something common, , my battery cables look fine too, my engine bay is squeaky clean, no corrosion or anything that I can see. No lights or anything are stuck on either.
Old Oct 20, 2008 | 06:52 PM
Formula413's Avatar
You said you tried pulling fuses, so I take it the draw was always present regardless of what fuse you pulled?
Old Oct 20, 2008 | 08:19 PM
sixvi6-camaro's Avatar
I had the same problem with my car when I was running Optima batteries.. My stock Delco got a little weak in the winter so I tossed in an Optima Red top. I went through 3 red tops in under a year. I Did all kinds of diagnosing and tried everything short of disconnecting the battery every time I let the car sit. I got fed up and tossed in the stock Delco and didn't have any more problems until the winter came around. I've been using a Duralast since then with no problems at all.
Old Oct 20, 2008 | 08:20 PM
J-Train's Avatar
Thats just it, from everything I can tell, there is supposed to be approximately a 3 mA draw from the alarm, ecm, etc, so my meter on the 2mA setting reads greater than 2 mA but when I switch it to 20 mA it is not reading anything, so I basically need to know if anybody has found the white rabbit, i.e the common fault, surely it is not something different on all the cars, it is a VERY common problem.
Old Oct 20, 2008 | 08:26 PM
J-Train's Avatar
I am familiar with your posts, I had a hard time believing it was the battery, so I went and exchanged the optima, and let the car sit for three days, it was from 12.79 volts down to 10.99, there is definately something drawing it down, funny thing you mention that though, on my 79 TA, I have a optima in it too go figure, and to some extent, but not as bad it has the same issue.
I may try a cheapo walmart batttery the next time I got TDY, and throw it in there for two weeks, just to experiment. It seems that no one has succesfully trouble shot with a amp meter and figured out the draw.
I have the amp unhooked overnight and am going to measure in the morning and see, after that, I guess I will disconnect the alternator overnight, although, the car is charging just fine, stranger things have happened.
Formula413's Avatar
That doesn't make sense, I would try a different multimeter. Without some information to work with you are just shooting in the dark, unfortunately.
Old Oct 20, 2008 | 08:34 PM
chaman's Avatar
Im in exactly the same boat as you guys. I have a yellow top (Optima). I tried to searcg for a significant draw but still nothing. Ive opted for giving the battery a charge at least once per week. Im also losing about 1 volt/24 hours. Mine is a 1999. I have good charger that prevents over charging and performs the function completely automatic.
Old Oct 20, 2008 | 08:57 PM
ultraz's Avatar
And this whole time I thought I was the only one with the unusual Problem with Optimas............ Ive been through 2 optimas in the past year and a half.... im on my third.
1st and 2nd Optimas had shorts in the battery cell themselves, the 1st one had such a bad short that my dash lights would come on all of a sudden if i hit a hard bump. 2nd one had less of a short.
On a related note, I had a draining problem as well, my car would not start if left alone for 2 days. Changed out the red top to another brand new one and no problems since.
What I DID find however, is that the + Terminal at the battery was almost eaten through. It was not noticable at all until I took the rubber cover off of it. I just ordered a new cable through GM.
PS.. I am a Mobile Electronics Tech and cannot believe how I missed the corrosion.
Old Oct 20, 2008 | 09:11 PM
J-Train's Avatar
Where was it corroded at? up by the terminal? I pulled the ruber covers and inspected, they looked clean as new, where the two positive cables run parrelel until they split, i did notice a ever so slight bit of chafing like the two positive leads were rubbing together, but for everything I can see, it is simply cosmetic and not even close to being through the sheathing. Alot more cars may have this issue and not even know it, If my car did not sit every now and then for two weeks when I am out of town i probably would never even know it. It is anoying as **** though, got to find it.
Old Oct 20, 2008 | 09:29 PM
chaman's Avatar
Hope you do...and tell us! Ive been wondering about this for a couple of years now without any luck...
Old Oct 20, 2008 | 09:34 PM
TA-Swede's Avatar
Same problem here.
I've got plenty of know-how with electronics though, so I'm certain I'll figure it out once I get to it.
I'll post up once I've got something to report.
Old Oct 20, 2008 | 09:37 PM
chaman's Avatar
One question....is this only related to Optima batteries?? If it is Im going to trash that POS! LOL!
Old Oct 20, 2008 | 09:51 PM
ultraz's Avatar
NO it could be any battery. It just so happens that these "Performance" batteries have given myself and a few friends nothing but trouble. The only problems I had with AC delco Batteries was that theyd last about 2.5-3 years and theyd start leaking.
The Battery Terminal problem is the Ring terminal right under the rubber cover.
Old Oct 20, 2008 | 10:17 PM
J-Train's Avatar
I thought too it could have been a Optima battery issue, I will but the cheapest battery i can find and throw it in my car next week for a experiment, i am going out of tow for two weeks, so I will try and see if it is just the optima's not being resitant to very small constant loads as a standard battery. (I thought the optimas were supposed to be better at this though)
Just a FYI, I had a delco battery in my car, but it was dead on one occasion after a trip, I charged it and the next trip I took it was dead again, so I replaced it with the optima. It may have been draining ever since I bought the car last Dec, but i just never noticed it.
Old Oct 21, 2008 | 10:30 AM
J-Train's Avatar
Update, I got a good fluke 77 meter this morning from work and we were reading about 71mA of static draw, not good, should be about 3mA from what I learned.
We pulled every single fuse on the car and not a budge on the meter. What next?
Old Oct 21, 2008 | 12:08 PM
CULATR's Avatar
GEZZZ THAT SUCKS.....i feel the pain as well as others, my car does the same on suckin the red tops dry if left alone for awhile in the garage. I've been thru 3 optimas batteries aswell, just havent had the time to track it down yet
Old Oct 21, 2008 | 02:01 PM
Grimes's Avatar
If you really did pull all the fuses, and nothing changed, then it must be a short somewhere before the fusebox...check all wiring in the engine bay, and also the wiring that goes to the fusebox. Could be a simple rub-through somewhere.
Old Oct 21, 2008 | 05:25 PM
J-Train's Avatar
It would be nice if it was that simple would'nt it, too many cars with the same issue. I have already checked all the wiring I know about, but I am bound and determined, I am going to check it all again, one other thing, I want to try and I could not try today at work, is to completely remove the alternator from the equation, exciter wire and all, my engine bay and all the wiring look brand new at a glance though, my car is a exceptionally clean 60K miler, that gets super babbied, no mods, not hammered on at all, looks as good as when it rolled off the line, but seems like all F-bodys have their share of issues, mine is no different. The list.............
Piston Slap (wtf)
Door panel cracks (wtf x2) fixed those btw
Rattle from rear hatch
Tight *** power steering
Bulbs poping all the time
T-top leaking
Slow *** windows
Headlight doors won't seem to stay aligned
Now the batttery drain........GM quality, got to love it.
I love my car though, love my car. Love hate relationship
Old Oct 21, 2008 | 07:17 PM
Grimes's Avatar
Piston Slap (wtf)
T-top leaking
Slow *** windows
Damn that sucks dude, sorry you have such shitty luck. A shot in the dark - how about the starter solenoid. I dont think it is fused (just a fuseable link?) Could it be faulty and draw more power? Try disconnecting the heavy wire to the starter.
Old Oct 21, 2008 | 09:44 PM
joshp14's Avatar
You will never get 3 mA draw from all the modules in the car. Typical parasitic drain is 20-30 mA without any aftermarket acc's. 71 mA shouldnt drain the battery in 1 day unless the battery is junk or undercharged.
Did you pull fuses on the I/P fuse block to see if the drain drops? You will have to do this with the d/s door open...but make sure you pull the interior lights fuse first or you may pop the internal fuse in the meter when you open the door.
Remove not only fuses, but relays and circuit breakers too. Some relays may be sticking causing the draw. Trust me...I've had my fair share of cases chasing down **** like this.
