Cooling issue
when the car is hot, with the cap on, have someone hold the engine around 2000-2500 rpm and then squeeze the upper radiator hose with your hand. You should feel a decent surge as coolant is flowing through it, if not your water pump may not be pumping or you may have air in the system.
with your current stat, it is a very good idea to check it in a pot of boiling water and verify it opens and closes without hanging up, other than that there's not much to cooling systems other than water pump, radiator cap, no air in system, and no clogs which i seriously doubt. you most likely have air in the system, keep checking the radiator level and top it off along with the overflow tank every time the car is cold. Also, when you fill the system via the radiator pull the throttle body coolant hose, that's a nice spot to let air escape as you pour into the radiator but you have to go slow and will take around 10 minutes. when coolant comes out the throttle body hose then reconnect and top off radiator and overflow tank.
So, what would cause my cooling system to take a dump when i put a thermostat in? I pull the stat out and the system works just fine, but I cant drive it in the cold because it will run really cold, obviously.
