Wiper motor
Thanks
Wiper Motor Replacement
TOOLS REQUIRED
J 39232 Wiper Transmission Separator
J 39529 Wiper Transmission Installer
REMOVAL PROCEDURE
Remove the wiper arms. Refer to Wiper Arm Replacement.
Remove the air inlet grille panel.
Remove the water shield.
Remove the screw and the nut.
Disconnect the RH linkage assembly from the LH linkage assembly with the J 39232.
Remove the LH linkage assembly.
Remove the screw from the wiper motor.
Pull the wiper motor free from the slots of the bracket.
Disconnect the RH linkage assembly from the wiper motor with the J 39232.
Disconnect the electrical connector from the wiper motor.
INSTALLATION PROCEDURE
Connect the electrical connector to the wiper motor.
Connect the RH linkage assembly to the wiper motor with the J 39529. IMPORTANT: When installing the wiper motor, be sure that the crank arm is in the innerwipe position. The crank arm drive pin must be engaged in the cam pocket.
Install the wiper motor with two locator pads pressed into the slots of the bracket.
NOTE: Refer to Fastener Notice in Service Precautions.
Install the screw.
Tighten
Tighten the screw to 10 N.m (7.5 lb ft).
Connect the RH linkage assembly to the LH linkage assembly with the J 39529.
Install the LH linkage assembly with the screw and nut.
Tighten
Tighten the screw and the nut to 10 N.m (7.5 lb ft).
Install the water shield on the LH linkage assembly with the flat side of the water shield under the windshield.
Install the air inlet grille panel.
Install the wiper arms.
This is crazy 2 days trying to fix this.
I believe I have the drive pin engaged in the cam pocket. Would anyone have pictures, or a diagram for me to confirm I have the correct pin in the correct hole? On the top where it connects to the wiper arm, I see a pin. Also, underneath there is a pin.
Also, if your wiper linkage seems to pop off. Make sure you use pliers on the knuckle and joint. I was hearing a pop putting the knuckle on by hand. That wasn't enough I really had to crush them on. I heard a louder pop and it seems to be finally all good to go.
