Sponsored by: CARiD
question about p1416 code
Old Nov 1, 2008 | 05:01 AM
Camaro Ryder KV's Avatar
Default question about p1416 code
hey guys,
i have noticed a sound during deceleration, kind of like a winding down noise very similar to the sound of a jet engine shutting down if that helps. i got a p1416 code being thrown, could this be causing this sound????
any help is appreciated,
thanks
kevin
Old Nov 1, 2008 | 11:01 AM
2001NBMZ28's Avatar
Probably not, the AIR activates during cold starts and the air pump is electrical. When I threw P1416 I didn't notice any noises, replaced the clogged check valve and the code went away. Guess you could check the air system hoses/connections for any leaks.
Old Nov 1, 2008 | 11:56 AM
Formula413's Avatar
They could possibly be related, I tend to doubt it though. Check the air injection pipe running into the passenger side exhaust manifold for any cracks or damage, if there was a leak in that line it might make a noise like that and also throw a P1416 code. But usually P1416 means the check valve in that line is clogged.
Old Nov 1, 2008 | 04:48 PM
peterock98's Avatar
YEP I had this code too. Replaced the check valves and no more problems....
