Sponsored by: CARiD
HELP. Locked keys in car.
Old Nov 25, 2008 | 07:23 PM
richard head's Avatar
Default HELP. Locked keys in car.
Anyone know how to get in?
Old Nov 25, 2008 | 07:31 PM
2002_Z28_Six_Speed's Avatar
Pull the window out from the aftmost topmost corner and then have a small handed girl grab the unlock slide.
I can break into any f body in 10 seconds or less with this method.
Old Nov 25, 2008 | 07:38 PM
Tried, no luck. Can't get a grip with my fingers, don't want to ruin the seal with a screwdriver. Plus, no small handed girls around. I do have access to wiring stuff and the hood is up.
Old Nov 25, 2008 | 07:48 PM
slayerized6's Avatar
if you got triple A, give them a call. if you want to play it safe, call a locksmith or just ask to borrow a slim jim.
Old Nov 25, 2008 | 07:50 PM
Kamaro Vsex's Avatar
slim jim works, I locked my keys in my car in front of a 711 while it was running. My boy came and opened it in less then 10 seconds.....****** honda thieves
Old Nov 25, 2008 | 07:51 PM
samson_420's Avatar
Slim jim all the way.
You can do it the old fashioned way with a coat hanger also.
Old Nov 25, 2008 | 07:52 PM
popalock guy just got here. 47 bucks i could ill afford to lose. thx 4 tryin man.
Old Dec 4, 2008 | 04:02 PM
99monguse's Avatar
If you have your registration/title you can have your local dealer make you a new door key to unlock the door by using the Vin# (they can get the code from GM, as longs as the locks are all original)
Old Dec 4, 2008 | 04:10 PM
eseibel67's Avatar
This is the way to do it.
Except unlock the power door lock with a yardstick. It won't damage the car.
Old Dec 4, 2008 | 04:32 PM
Do you have a 98?
My unlock button stops working after about 10 minutes. You can depress it and nothing will happen.
Old Dec 4, 2008 | 07:50 PM
GMRL's Avatar
My 97 disables the power button when the alarm is armed. Im sure they all do. Is the alarm armed on your car?
Ive locked my keys in the car several time, even with the battery unhooked. I went to Lowes hardware, picked a flat piece of alumium and folded the end at a 90 degree angle about 1-2 inches. Pulled the passanger side window out a bit with a pry bar and was able to unlock the manual bar.
Old Dec 5, 2008 | 01:10 AM
bowtiekid's Avatar
^^^ +1 its so damn easy. Just get your fingers in there and hold it back. If you dont lock your t-tops unlock it. push it up, then move it out of the way and then unlock it, much eaasier lol
Old Dec 5, 2008 | 01:22 AM
the_merv's Avatar
Veteran: Air Force
^^Yea, but that works for a T-Top car, right..
Old Dec 5, 2008 | 12:38 PM
99monguse's Avatar
Another thing you can do is pry the window out just enough to get some kind of shaft to reach the lock slide across the car to the other door. But getting a new key cut would be easier.
Old Dec 5, 2008 | 01:00 PM
firefighter813x's Avatar
Do exactly as the other poster said. You really have to pull hard on the window towards you. I can barely get my hand in there to unlock the door. It's not painful, but not comfortable. I've done it many times and thought of how easy it would be to break into someones car! lol
Old Dec 5, 2008 | 01:02 PM
Posi12Bolt's Avatar
Default should work?
btw, mine is a hard top.
Old Dec 5, 2008 | 01:03 PM
Yeah, I think that will work too! hahahaha
You live in Vaca? I grew up in Vaca....
Old Dec 5, 2008 | 04:39 PM
hutch1999's Avatar
Originally Posted by Posi12Bolt
lol thats how they stole my radar detector last summer.
If you happen to know a cop personally they can get into a car or I would call a locksmith and pay the thirty dollars
