car not starting (not ls1)
my DD decided not to start last night so im trying to figure out whats wrong. so the car started then sputterd (sp) out, i tried again and the same happend, then the third time it wouldnt start at all. i did kinda overfill the gastank yesterday and was wondering if that could be part of the problem?
if so would i just pull out the plugs and deflood the engine?
its a 99 saturn sc1 automatic
My first guess is the fuel pump is gone. Turn the key on and listen for the fuel pump whine...if none, check for a fuel rail schrader valve and turn the key on and depresse the valve and see if fuel spurts out....if not..then it is probably the fuel pump!
thanks for the help so far, ill have to check the fuel pump, the worst part is i bought the car for winter and snow to keep the TA nice, and the night it breaks down it starts to snow
well it starts now but its real ruff and you have to keep giving it gas, but then it settles down and runs fine, could that be the crank sensor or somthing else?
