SECURITY Light on
Any insight???
dont know why my light is on. i cleaned the key but still wont go away.
there are a few solutions, try to free those contacts so they move freely, disable the vats through a tune, bypass it with a resistor, replace ignition.
For mine i just unplugged the vats sensor wires, security light stayed on but always started and ran fine. not sure if it will work for everyone, but you can give it a try.
under the steering column, remove the large panel. there is an orange sleeve with two wires in it, a puple an white one, it goes toward the ignition. about halfway to the firewall there is a connector, unplug it and see if it will start
http://www.lt1swap.com/vats.htm
here is the wires i left unplugged
and a thread from a little while ago
https://ls1tech.com/forums/lt1-lt4-m...d-ole-lt1.html
Im not sure about the steering column thing, follow that orange wire up the column till you find a kink if there is one?
The BCM is still messed up on mine. After trying the resistor trick it still wouldn't start consistently. So I tuned out the security shutdown and wired up the ignition straight to the starter relay to bypass the BCM. I can crank the car everytime now but my light still comes on. I honestly didn't feel like going through the hassle to get a new bcm and matching the keys up yadda yadda yadda. I guess I need to get a real security system now.
If your getting a custom tune the tuner can tune it out and you can bypass the BCM if you have to.
As long as your BCM is good you should be able to fix it on the cheap with the resistor trick.
I would definitely try the resistor first. If it works with that then you can probably fix the wires in the column or at worst have to replace the cylinder.
Also I unplugged the VATS connector (where the purple/white and white/black wires meet the two wires w/ the orange sleeve) and it still will not start. I was able to push start the car to get it home, but the problems not fixed and it still will not start.
There was a how to I ran across at some time but can't find right now shows putting the proper resistor across a two wire plug under kneepad-good luck!
http://www.ls1.com/forums/showthread...ht=bypass+VATS
