Sponsored by: CARiD
car won't start
Old Jan 13, 2009 | 07:28 PM
1sickta's Avatar
Default car won't start
everytime i try to turn it on,it make weird noise. i guess its time for change the starter but i don't know where the starter is and how to change it can anyone help me
Old Jan 13, 2009 | 07:46 PM
2001NBMZ28's Avatar
What kind of noise? If it's a rapid clicking sound could just be the battery.
Old Jan 13, 2009 | 10:39 PM
LS6427's Avatar
Don;t do anything until you check some things out.
Old Jan 14, 2009 | 12:24 AM
1sickta's Avatar
baterry is ok,but when i try to start it make trrrrrrrrrrrrrrkkkkk sound then the mph needle going crazy
Old Jan 14, 2009 | 01:19 AM
LS6427's Avatar
Is it a fast tick,tick,tick,tick,tick,tick? Could be the voltage regulator. But yeah, it could be the starter too.
If it were me, I would go get a new starter at PepBoys or Advance and put it in, doesn't take long to change it out. If it works, keep it. If it doesn;t you can always return it for a refund...just clean it up.
Old Jan 15, 2009 | 09:07 AM
1sickta's Avatar
where is the starter locate it?
Old Jan 15, 2009 | 09:36 AM
toothdoc's Avatar
On the bottom of the engine block. You will need to get it up in the air to change it.
Old Jan 15, 2009 | 11:24 AM
the_merv's Avatar
Veteran: Air Force
Disconnect the Battery first.
Old Jan 15, 2009 | 03:06 PM
2001SSpewtm6's Avatar
If its a rapid tick, and engine does not turn over. Check the battery first under a load. If battery is low, charge up and retest. If the battery test good and it starts check alternator & wires to alternator for problems.
If it does not start after you are sure the battery is good. Check power and ground wires, then starter. Hopefully it is something simple. If you need help give me a call.
Old Jan 15, 2009 | 03:21 PM
SparkyJJO's Avatar
That sounds like the battery not the starter. Mine did that when the battery died (it was 10 years old, came with the car off the assembly line). How do you know the battery is good? How old is it?
