do it yourself tuneup
you will hear clicks when you press the wires on the coil's and the plugs, don't overtighten your plugs either
A ratchet
5/8" deep socket for spark plugs
Extension and swivel
10mm deep socket or 10mm ratcheting wrench (for the coil bracket, a regular socket will NOT work and a regular wrench will take you forever)
For the fuel filter, I dont remember what size wrenches you will need, but like the other guy said open your gas cap, and relieve the pressure out of your fuel system. You do this by taking off the little screw on cap at the end of your driver side fuel rail, which will uncover the shrader valve. Get a paper towel and press on the little needle and a little bit of fuel will squirt out. Remember to use lots of rags for the fuel that will drip out of the line going into the filter.
Theres a great write up for both of these at www.installuniversity.com
I lay across the lid and with my left arm/hand, I reach back to the rear passenger side plug, same with the next 2 plugs on that side. The front one is easy. The drivers side is plain simple.
Its all about the little tools. And hopefully the person that put the plugs in the last time didn't crank them down heard like a dumbass. Hand tight, then a tiny little snug is all they need.
These tools are for the passengers side. Regular sized ratchets for the drivers side. And remember to be careful not to snap that coolant sensor off just above the front plug on the drivers side.
Fuel Filter
http://www.installuniversity.com/ins...lacement_1.htm
Spark Plugs and Wires
http://www.installuniversity.com/ins...sity/index.htm
