~~HELP! No headlights ~~
oh yeah its a 2000 Trans Am A4
You pull the round rubber boots with the long nipple on them, off. Then crank them up. Pop the hood and you'll see them. Just rotate them until the lights are all the way up. Then you will be able to turn them on and off normally.
Thanks again
Not sure if these cars have anything like that or not but it is worth checking! The Best V8 Stories One Small Block at Time
1. Fuse, Relays
2.Bad Switch
3. Bad module
Thanks again.
relay, fuses
switch
module
bad wire
testing a relay isnt hard, just connect the coils of the relay (which i think would be pins 86 and 87 i believe) to a power source-an you should hear it click--or do a continuity check across the coils with a multimeter-if the relay checks out then check your switch-an just go from there
relay, fuses
switch
module
bad wire
Still have the problem! No low beams!
I'm still at a loss for my issue. It's a California car and all the grounds are good.
Just my .02
