Sponsored by: CARiD
help bleeding clutch...
Old Jan 24, 2009 | 06:26 PM
lexva_58's Avatar
Default help bleeding clutch...
I took my engine out to put new gaskets and main seals on my ls1, while there I decided to put a new clutch. The mechanic decided to disconnect the hoses that feed the master and slave cylinder. Everything is installed and ready the HUGE problem is that we have been trying to bleed the clutch like for three hours and gears just wont go in, should I keep bleeding it till it gets the gears or is there another way I should be doing this? Im bleeding it the traditional way.one guy pushing the pedal and another one opening the bleeder..
thanks in advance, any help is appreciated
Old Jan 24, 2009 | 07:20 PM
9000th01ss's Avatar
Jack the front of the car up higher than the back.
Fill the fluid. Open the bleeder half turn.
Wait til fluid comes out by gravity.
Close the bleeder.
push the pedal down half way a few times. Open the bleeder again and let fluid come out on it's own.
Close the bleeder and you should be good to go, although it seems I'm the only one who can get away doing it like this.
Hopefully no one floored the clutch pedal yet, but thats usually the case.
Old Jan 24, 2009 | 07:31 PM
jomomma's Avatar
i just put in a new clutch and had all kinds of problems trying to bleed the slave cylinder! first off, you know you have to have the cap on with the diaphram out when bleeding. after bleeding it for about 45 minutes we decided to blow compressed air from a blow gun into the tiny hole on top of the resovoir cap. as soon as we did that it started working. try it!
Old Jan 24, 2009 | 07:39 PM
jattgunman's Avatar
Just rent a mighty vac and youll be done in two minutes..theres a site that shows you how to do it with a ls1 and its super easy.
Old Jan 25, 2009 | 06:03 PM
gnomee's Avatar
+1 for the Might Vac. It has worked great for me several times. Here is a link I found on how to do it
http://www.performanceworks1.com/ls1...h_bleeding.htm
Old Jan 25, 2009 | 06:28 PM
Sharpe's Avatar
I got a remove bleeder before I heard of the Mighty Vac. Mighty Vac would be the best, I would say.
Old Jan 25, 2009 | 06:56 PM
00silver6's Avatar
+ mighty vac is what i use too
Old Jan 27, 2009 | 05:13 PM
lexva_58's Avatar
thanks to all.. ill try suggestions tomorrow to see if any helps at all...
Old Jan 28, 2009 | 12:24 AM
rich Z's Avatar
I have a motive power bleeder that I have used to do brakes for yrs and this last saturday I flushed the clutch out fast. I cut a hole in the trans tunnel to access the bleeder nut. Now I can bleed and flush the clutch out in probable 10 mins.
Old Feb 4, 2009 | 01:20 PM
RsSean's Avatar
That is a very good link to help me out tonight, Thanks.
Old Feb 4, 2009 | 01:34 PM
gnomee's Avatar
No Problem! Glad it helped.
Old Apr 5, 2009 | 01:40 PM
Eddie 70's Avatar
This appears to have worked for us too. Give it a little while when you are working and it works. I broke vacuum a few times to check and see if we were getting anywhere because we were not seeing bubbles in the line like described. Everytime we pulled the fitting out of the master, fluid would be drawn down into the clutch system. After about 4 or 5 times of these cycle we began to see progress and now have a good clutch feel. When we started we had nothing at the pedal.
Thanks for the link and thanks to whoever came up with this method.
