Lovely Door Crack
Does anyone off the top of their head know the part number for the door piece?
and I do realize its the ENTIRE door pretty much, as its one piece.
There are some good ideas in here and some that are not so good. I'd recommend checking out post # 312. DarthD has a great fix to relieve the stress. I tried his mod/fix and my crack closed up tight. (Then it can be repaired.)
so it went in the shop to get replaced. Good thing I got the warranty on the motor when I got it 10 months ago. No idea why this motor spun a bearing, only had 70k miles on it and it looked good when I had the oil pan off back in November. Who knows... Anyway, I'll be taking care of the dash when I get the car back.My car just hates me
Im going to be taking out the staples this weekend as my car doesnt have the cracks yet but its got a slight dent in both doors.
All plastics shrink, which is normal and fine. All of the fasteners that secure the panel to the door have sufficient play to allow for this. The issue with the door panels is that the strip stapled in to the top of the panel does not shrink but its securely stapled in to the plastic. When the plastic shrinks along the staple line, it builds up stresses and then cracks (every door at the same place) where there is a weak point in the reinforcement in the back of the panel.
This is evident by the gap in the crack. When you remove the staples and relieve the shrinkage stress, the crack will close up. (If its not too big.)
