Sponsored by: CARiD
The clunk
Old Feb 9, 2009 | 02:21 PM
jdiddyws6's Avatar
Default The clunk
I've had a bad clunking noise comming from my rear passenger area for some time. It's heard on bumps...and VERY noticable going over a rock road that has minor imperfections. Exhaust is not rubbing, made same noise before and after installation of control arms. Any ideas?
Old Feb 9, 2009 | 03:49 PM
blade2222's Avatar
loose shock or reamed c/a mounting holes?
Old Feb 9, 2009 | 03:54 PM
nemss1's Avatar
ya like said, check your control arms and shock
Old Feb 9, 2009 | 06:29 PM
jdiddyws6's Avatar
Shocks are good...can anything be done about the reamed mounting holes? Body side or rearend side? Anyway to check?
Old Feb 9, 2009 | 06:37 PM
blade2222's Avatar
jackup rear on jackstands under frame letting the axel hang, then see if there is any movement when you push the tire toward the front or back of the car.
Old Feb 9, 2009 | 06:43 PM
nemss1's Avatar
could also be the pinion hitting the ring as well. thats what my clunk is
Old Feb 9, 2009 | 06:47 PM
jdiddyws6's Avatar
Imma do this tomorrow. If there is slack, is there any way to fix it??I seriously doubt it's the rearend because my old one did it, and this is a completely different sound. I seriously bought lca's/phb and shocks trying to fix it
Old Feb 9, 2009 | 08:15 PM
kbras12's Avatar
Check to see if you have bump stops!
Old Feb 10, 2009 | 10:31 AM
jdiddyws6's Avatar
I will, but because it's doing on on small stuff (rock road) it tends to lead me away from that because the suspension is not really flexing
Old Feb 11, 2009 | 08:15 AM
slvr98camaro's Avatar
check the torque arm also
im having the same type of noise, and im still unable to locate it
Old Feb 11, 2009 | 11:17 AM
SOMbitch's Avatar
Sway bar endlinks will clunk too. Check the LCA's are tight and bushings are good.
Old Feb 11, 2009 | 12:57 PM
CamaroFan71's Avatar
Mines been doing it also. Sometimes over little bumps and then it wont over huge bumps, which makes me think it isnt chassis flex. I just put BMR LCA's on it a few weeks ago that I had and it didnt help. Guess I have more things to check now also.
Old Feb 11, 2009 | 02:23 PM
crossroads's Avatar
I get the same rattle/clunk on my driver side rear but i have replaced:
LCA bushings
Adj Panhard
Lowering Springs
KYB AGX shocks
New sway bar & Bushings
Poly TQ arm bushing
Dana S60 rear
new rotors & pads
new drive shaft & U joints
and asfter replacing all that the rattle is still the same it was when i bought the car
Old Feb 11, 2009 | 03:02 PM
LCA bushings
Adj Panhard
Lowering Springs
KYB AGX shocks
Poly TQ arm bushing
Dana S60 rear
new rotors & pads
Thats a whole new car in the rear now!! Sometimes it makes me want to slam mine into a freaking tree when I hear that clunk also. Next im going to take the whole interior in the rear section out and see if its something in there.
Old Feb 11, 2009 | 04:12 PM
johnnybravo's Avatar
Check your door hinges. Check your driver's door first. Open the door all the way, and lift up on the rear of the door. if there's any wear you'll be alble to tell. The door will move up before the car lifts with it.
Old Feb 11, 2009 | 05:21 PM
Texas 02 Z28's Avatar
My PHB bolt comes loose a bunch. Like, a lot. Not even that much, it's like half a thread, just enough to **** me off, lol. This next time I'm going to locktite that sonofabish... Makes the whole car feel ghetto, lol.
Violently shake the PHB on both ends (one at a time) and see if it makes any noise at all. Tighten it and hopefully that's it.
Also, possibly check the spare tire well?
Old Feb 11, 2009 | 06:20 PM
crossroads's Avatar
the wife thinks i'm imagining the noise just to buy more mods at this point....guess ill have to figure it out so I can say the motor is clanking & say my cam is bad
but seriously the only time the clunk doesn't drive me nuts is when i open the cutout
let us know what you find & i'll try to do the same
Old Feb 12, 2009 | 10:00 AM
jdiddyws6's Avatar
There's nothing in the spare tire well. I'm going under the car shortly
Old Feb 12, 2009 | 10:52 AM
firefighter813x's Avatar
LCA bushings
Adj Panhard
Lowering Springs
KYB AGX shocks
Poly TQ arm bushing
Dana S60 rear
new rotors & pads
I had the same sound coming from the driver rear. I replaced my whole suspension and it fixed it. But.... It's coming back. Sometimes it's the hatch that comes loose, but It did go away the first time after replacing the rear suspension. Tighten and torque all bolts, and lube the poly bushings too.
Old Feb 12, 2009 | 11:26 AM
crossroads's Avatar
its funny you say that because when i installed all the items (basically at the same time)...the noise was gone, then after a week or two of driving on our wonderful new orelans roads the noise was back
looks like ill take your advise and re lock tite & torque all the bolts, thanks for the advice
